Online Now [52]:
Visitors: 51
Today: 73283
Total: 117323160
Forums › The Car › 206 Problems › 206 Help, Asap.
206 Help, Asap.
PostPosted: Sun May 08, 2011 10:18 am Up
Could do with a picture of a 206 PREPLEXED fusebox. Under steering wheel please.
I ask because I have re-wired my cooling fan, and when I have turned on the AC I still can't hear a 'click'.. Now I know the fan works as I have bypassed the relay switch (after buying two new relays) yet I can't be arsed to leave the car running til it gets to 90+...
So after inspection of the fuse list compared to my fusebox, I *think* that I may have a fuse missing. however don't wanna go sticking a fuse in anywhere. So, please. Picture of your drivers footwell fusebox please. Smile
PostPosted: Sun May 08, 2011 10:23 am Up
Do you have gass in the Air Con system? If you dont the it will not click in Tom I had the same problem.
PostPosted: Sun May 08, 2011 10:26 am Up
Ahhhh.. ok. That could be the issue. There is no gas because half the piping isn't in Wink
Well basically here is my problem.
luke wrote:
Passenger Fuse Box (12 fuse)
Fuse - Rating - Circuit Protected
F29....10A.........LH main beam
F30....10A.........RH main beam, main beam warning light
F31....10A.........LH dipped beam
F32....10A.........RH dipped beam, dipped beam warning light
F33....5A...........Headlight wash
F34....10A.........LH side/tail light
F35....10A.........RH side/tail light
F36....----- .......Spare
F37....----- .......Coolant temperature unit
F38....5A...........Fan, pressostat
F39....----- .......
F40....20/40A....Heating, ventelation
36 has a 5a fuse in it but 38 doesnt have any fuse?
PostPosted: Sun May 08, 2011 10:31 am Up
If you have no gas as no pipes are there that could be your problem then.
MrrNoName
PostPosted: Sun May 08, 2011 10:32 am Up
as said the compressor wont click in with no gas
PostPosted: Sun May 08, 2011 10:33 am Up
Right. Thats that. The clicking isn't my problem, it's just the fan still doesn't engage.
So what about the fuse 'missing'?
PostPosted: Sun May 08, 2011 12:53 pm Up
fuse for the fan is in the fusebox under the bonnet isnt it?
perry081064
PostPosted: Sun May 08, 2011 1:09 pm Up
pretty sure i havent got gas in the system and mine does click in when pressed.
although, my fan doesnt work due to wiring rot at the relays (now rewired), so cant be sure what else its affecting anyway.
air doesnt feel cool iether.
if you still need a pic i can sort you one in the morning.
206 2.0 HDI
perry081064
PostPosted: Sun May 08, 2011 1:10 pm Up
ive got one there for my fan anyway, clips into a yellow connector.
206 2.0 HDI
PostPosted: Sun May 08, 2011 1:44 pm Up
Can you get me a photo tomorrow bud? Smile
perry081064
PostPosted: Sun May 08, 2011 5:16 pm Up
will do Wink
206 2.0 HDI
PostPosted: Sun May 08, 2011 5:23 pm Up
perry081064
PostPosted: Mon May 09, 2011 5:47 am Up
as promised Wink
206 2.0 HDI
scousemouse
PostPosted: Wed May 11, 2011 12:59 pm Up
if fan does not come on with the air con check the low speed fan resistor located in the radiator fan housing you can get to it if you loosen the two 6 mm bolts holding the bottom of the bumper and get at the bolt holding the resistor to the housing if you use a multimer on continuity setting you are looking for continuity between all 3 pins or measure the resistance it should be 0.8 ohm
if you can\'t fix it with a hammer your problem\'s electrical
PostPosted: Sat May 14, 2011 8:13 am Up
Mine...
Which picture is correct?
