Latest: Stu-mill
Overall: 17131
Online Now [72]:
Visitors: 71
Today: 9041
Total: 104918643
Forums › The Car › 206 Talk › Best paint for fuel cap
jbrown171
PostPosted: Mon May 09, 2011 8:49 am Up
Wanting to paint my fuel cap, got an aftermarket GT style metal one. What black paint do you think would be best as in what type?
Cheers
1.4 LX
Dulux.
Danw_VVT
PostPosted: Mon May 09, 2011 8:50 am Up
Rolling On The Floor Laughing
jbrown171
PostPosted: Mon May 09, 2011 8:56 am Up
No seriously, im new to this. I know spray paint but what types the best to use? How many coats?
1.4 LX
Danw_VVT
PostPosted: Mon May 09, 2011 8:59 am Up
use a primer after keying the surface etc then normal car spray paint and some good lacquer! Smile
Andrew
PostPosted: Mon May 09, 2011 9:01 am Up
I done mine, you will get the best quality by sanding thoroughly with 600ish grade sandpaper, then 3 light coats of etch primer, dry sand with 1000 grade, 3 or 4 light coats of colour (halfords can will do) sanding 2000 grit inbetween coats that have been allowed to fully dry, then 3 coats of lacquer, 2000 grit on the final outcome and use a good polish
My 206 thread
www.detailedbyandrew.com
Rob2859
PostPosted: Mon May 09, 2011 10:32 am Up
If you want a plain glossy black use hammerite smooth in spray form. Its good stuff and you don't need to primer or anything. Thats the easy and idiot proof way Very Happy
jbrown171
PostPosted: Tue May 10, 2011 4:04 am Up
Cheers, yeh I think ill try this way sounds simplest.
1.4 LX
