Posted: Mon May 09, 2011 2:39 pm |
And it will obviously have a wire sticking out of it
Posted: Mon May 09, 2011 2:43 pm |
indeed, should be easier to see then. Though knowing me, id probably still miss it! doh!
Posted: Mon May 09, 2011 2:45 pm |
So 6 is the relay, 5 is the resisitor right? (i read it could be this). Though whats 13? Temp box??
Posted: Mon May 09, 2011 3:23 pm |
is this it??
Yep that's the one I think!
Posted: Tue May 10, 2011 1:25 am |
Sweet, its the only green one I can see in Ape's pics!
Reading online, I understand it cant be the thermostat so can rule that out. I guess ill try the sensor then if not, try the relay,resisitor stuff etc on the fan!
hmm and the fan doesnt come on when the AC button is clicked?!!
Posted: Sat May 14, 2011 5:19 am |
The low speed fan and high speed fan work fine but the car temperature is still getting hot (as in the needle shows this)
Any ideas what this can be? Ill try changing the temp sensor when the car cools down - will coolant spill out from here or can I literally take that one out and replace it straight up without doing anything else?
