Online Now [526]:
Visitors: 525
Today: 245111
Total: 146699973
Forums › The Car › 206 Problems › Jord: Couple of problems... FIXED
Go to page Previous  1, 2
PostPosted: Thu Apr 21, 2011 7:47 am Up
Addaz wrote:
JordGJ wrote:
no i don't have aircon
Do you have a large or short radiator?
not sure, how can i tell?
PostPosted: Thu Apr 21, 2011 7:49 am Up
Does it span about three quaters of the front, or only half?
Small
Large
Addaz wrote:
tomd0801754 wrote:
IIRC Its a bumper off job.. If your looking at the fan housing from the front its the bottom left cover. (You will knwo what I am on about when your looking at it..
Its only if he has aircon mate
Otherwise its not that at fault
(non aircon have different fan setups)
Ahhhh. Learn something new everyday... Smile Ignore my post then (obviously)
PostPosted: Thu Apr 21, 2011 7:51 am Up
Small
Large
not completely sure will look later but i would guess that its the smaller one being a pretty low spec 1.1?
PostPosted: Thu Apr 21, 2011 7:54 am Up
Yeh, you will probs have smaller one
I dont quite know tbh then mate, check the fuses, see if the fan is connected
Find the fuse that operates the fan, put i live down the one that goes to the fan, does it turn on?
If not, its the fan/wire to fan
If it does, fuse or sensor
PostPosted: Thu Apr 21, 2011 7:55 am Up
yeah i thought the same as you there... where are the fuses for the fan though i can't see any that are gone in the box under the bonnet or under the steering wheel? Confused
PostPosted: Thu Apr 21, 2011 7:56 am Up
JordGJ wrote:
1. My LED rear lights have gone mental, the passenger side is fine but the drivers side does strange things; sidelights and braking are fine, that works normal but then the problems start. When i indicate/put hazards on the amber light flashes very dim and the main red led part also starts to flash! (don't understand that Confused )... the reversing light is very dim compared to the passenger side... i've tried unplugging them and making sure they are all connected properly... i will try bulbs later but doesn't seem like its a bulb... any ideas?
Earthing problem, or a loose connector
2. My electric fan won't kick in... i know this has been asked before but it's annoying me now so would like some advice lol; had the sensor tested and that is fine apparently (well it changes the temperature on the gauge at least), the fan itself is not seized either. Could it be a fuse/relay? if so could someone tell me where i would find them (51' preplexed 1.1) because i cant understand most fuse/wiring diagrams Laughing
If you have AC, turn that on to see if it works. If not, then it more than likely will be the relay or a corroded wire.
Thanks, Jord
PostPosted: Thu Apr 21, 2011 8:02 am Up
IIRC its a big one on the wall closest to you, not wing or battery side, or strut side
But headlight side, follow the wire to see if im correct
If i am, give it a live from battery, does it work?
tofy92
PostPosted: Thu Apr 21, 2011 9:19 am Up
London Area Rep - tofy92
i had same issue with rear ldrivers light turned out it was just a loose wire in the connector block for the lights
PostPosted: Fri Apr 22, 2011 5:46 am Up
lights sorted fan still a problem though...
PostPosted: Tue May 10, 2011 3:27 am Up
fan solved yet?
Page 2 of 2
