![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › Best way to clean coolant reservoir? |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Thu May 12, 2011 5:10 am |
People like Radtec or Allisport will probably make a custom reservoir. Might look a bit blingy though.
| | ![](images/spacer.gif) |
| ![](themes/base/images/forums/otr.gif) |
