Latest: Worthy967
Overall: 17143
Online Now [555]:
Visitors: 554
Today: 134028
Total: 114710150
Forums › The Car › 206 Problems › Intermittent power loss
Go to page Previous  1, 2
cosmicdance
PostPosted: Sat May 07, 2011 12:53 am Up
It's definitely worth getting it to a reputable auto technician (not expensive Peugeot!) to get the fault codes read.
If there is a fault with fueling etc then it should come up on the diagnostic machine as yours sounds very consistent.
Andy
Andy
nashy
PostPosted: Sat May 14, 2011 10:18 am Up
ok
happened the other day again i got the right hump and drove it in 2nd gear screaming the balls of it.....
it made some weird noises a bit of smoke and since then it drives a lot smoother and i aint had the probably since so fingers crossed
nashy
cosmicdance
PostPosted: Sat May 14, 2011 11:55 am Up
Yes I have cleared mine before by thrashing it. Not redlining though!
usually it has started it again at a later date though.
I had my EGR valve replaced last week and have been on a motorway run for 70 miles today and it hasn't missed yet.
I will let you know if this is consistent though.
Andy
Andy
cosmicdance
PostPosted: Sat May 21, 2011 6:43 am Up
I had the EGR replaced a couple of weeks ago and the intermittent power loss hasn't happened since.
Hopefully this will have sorted it.
Until the next problem!
Andy
Andy
stevo2709
PostPosted: Wed Oct 09, 2013 3:01 pm Up
Andy did the problem ever return after replacing egr valve? Thanks
cosmicdance
PostPosted: Wed Oct 09, 2013 11:49 pm Up
Yes the intermittent power loss returned again after Replacing the EGR.
In the end it was the crankshaft sensor which was faulty.
Got that replaced a couple of years ago and its been perfect power wise ever since.
Andy
Andy
gazza82
PostPosted: Thu Oct 10, 2013 8:00 am Up
My 1.4 hdi's power loss was the cat ... the core collapsed.
Not easy to diagnose as I had a problem with the glow-plug relay at the same time. But after curing that and losing power again on the motorway decided to check in the cat pipe ... not a pretty site!
hoganblue
PostPosted: Sat Jul 26, 2014 6:11 am Up
I have a 206sw Dturbo which suddenly beeps and stops ! was told it was the crash collision sensor. This was reset at the garage but today has done it again ! No I have not had a crash or bump . Anyone know how I can remove this please.
Page 2 of 2
