Latest: cogeim7
Overall: 17185
Online Now [960]:
Visitors: 959
Today: 164133
Total: 147277832
Forums › The Car › 206 Problems › Rear lights
Rear lights
Twisted
PostPosted: Sat May 14, 2011 3:50 am Up
I have a v reg 1999 206 gti the probably im having is i went to fit led bulb in my crystal light cluster and i noticed that the left rear light is out the rake light works but when i trun on headlights only the right side illuminates the reversing light and indicator are fine just the near side night running light wont light i tried putting in a standard bul but this did not clear the issue,
If any one can offer any advice or help i would be greatful
thank you in advance
V reg 2000 Gti
ukskater01
PostPosted: Sat May 14, 2011 7:52 am Up
Check the connections on the bulbs and plug are secure, there's also a plug by the passenger footwell that could have been knocked out by accident.
If you can get a multi meter check all the connections have continuity (make a circuit)
Hope that helps
Twisted
PostPosted: Sat May 14, 2011 11:56 am Up
i found it thanks it has its own fuse that had blown feel a right doofus now lmfao
V reg 2000 Gti
PostPosted: Sat May 14, 2011 12:09 pm Up
Your not the first and probably not the last one on here that ha blown a fuse changing a bulb.
