Latest: Kifi69
Overall: 17183
Online Now [514]:
Visitors: 513
Today: 27229
Total: 144318849
Forums › The Car › 206 Problems › Car overheating help!
Go to page Previous  1, 2
PostPosted: Sat May 14, 2011 10:38 am Up
Sounding like a new water pump & timing belt kit then Wink
PostPosted: Sat May 14, 2011 10:41 am Up
Ah ok i think ill get that done next doh. Would you say its ok to drive for 5 days with it like this??
PostPosted: Sat May 14, 2011 10:43 am Up
not ideal to drive it, make sure the temp doesnt get to high else it can blow the head gasket.
Ash
PostPosted: Sat May 14, 2011 10:45 am Up
Windows down, heating on full hot Razz Should be fun in summer..
PostPosted: Sat May 14, 2011 11:00 am Up
Been doing that! lol
PostPosted: Sat May 14, 2011 12:16 pm Up
ok thanks Smile
leigh_boy
PostPosted: Sat May 14, 2011 12:27 pm Up
i know this sounds odd, but i have known people to put the thermostat in the wrong way, id be temeped to take the thermostat out and drive it that way if it runs cool you know you put it in the wrong way Smile
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Sat May 14, 2011 12:28 pm Up
hehe thanks but I def put it in the right way! Also the car was acting up before changing the thermostat too. (Just tested the old thermostat and it worked fine). What a waste of money!! Sad
leigh_boy
PostPosted: Sat May 14, 2011 12:35 pm Up
sounds like needs bleeding or water pump then,
*DEAD*206 Gti 138
PostPosted: Sun May 15, 2011 8:34 am Up
its going to be bled tomorrow then if that doesnt solve it then waterpump+belt+tensioners change.
I dont get why the thermostat doesnt open though. The housing side is warm pointing that the coolant is hot but the other side of the thermostat is stone cold hence the radiator being cold.
Unless that means there is a air pocket like right next to the thermostat?
leigh_boy
PostPosted: Sun May 15, 2011 1:24 pm Up
its not opening because there eis no water moving around
*DEAD*206 Gti 138
PostPosted: Sun May 15, 2011 2:49 pm Up
oh ok. sorry still trying to figure out the cooling system properly!
PostPosted: Mon May 16, 2011 4:51 pm Up
all sorted now. new waterpump.cambelt and radiator.
-RAJ-
PostPosted: Mon May 16, 2011 6:35 pm Up
dont know if this is relevant but my engine temp sensor was changed by pug last week for free, as there was a recall on it
PostPosted: Mon May 16, 2011 11:25 pm Up
probably not now but nice to know! Ill have to check if mine was recalled for the change and anything else if there was! Smile
Page 2 of 2
