Posted: Sat May 14, 2011 1:09 pm |
I feel like an idiot, it took me 2 hours to do the clock. It was a true nightmare, when it was all connected the clock would just appear then disappear, I had to use tape to stretch out the wires at an angle. Yes, circuit was vulnerable... but got there in the end
Anyway... can someone use paint and edit imageshack.us/m/62/163...011463.jpg to tell me exackly what to do? Please... right now I need a drink from this.
Thank you.
Posted: Sun May 15, 2011 6:23 am |
Swop the red & yellow wires at the bullet connectors
Unplug both.
Plug the red wire in to the yellow one.
Then do the same again with the red / yellow wires left over.
Posted: Sun May 15, 2011 7:25 am |
Posted: Sun May 15, 2011 7:27 am |
That ^ hahaha!
| 2001 1.4lx
PrePlexed 5 door. | |
Posted: Sun May 15, 2011 9:46 am |
Omg it was that simple... what! I tried doing exackly that before but thought this can't be it as you need to really pull it out with pressure.
Thanks alot, settings save now
Posted: Sun May 15, 2011 11:52 am |
Well I need a new clock now, when I turn off the engine for 5 mins then on again, the clock doesn't turn on so I have to open it up and push something towards the circuit. This somehow triggers it on and not when I turn on the battey with the key?
Circuit problem?? Need new clock?
Posted: Sun May 15, 2011 11:55 am |
Preplexed 206 like this, the displays always go wrong
You got just a clock or multifunction display?
There is a known issue with the solder joint on the pcb inside the multi function display
Posted: Sun May 15, 2011 1:30 pm |
I have a single display clock, knowing that I need a new one am I able to purchase a multi function display or can I only get that single one? I ask because it is rare to find these nowadays...
