Online Now [696]:
Visitors: 694
Members: 1
Today: 126352
Total: 145236620
Forums › The Car › 206 Talk › Air , hissing noise coming from coolant tank
Forum Index › 206 Talk
Go to page 1, 2, 3, 4  Next
eddrj
PostPosted: Sun May 15, 2011 12:27 pm Up
Just noticed werid air noise coming from coolant expansion tank any ideas , ? anyone else had this ?
Is it air lock or need new cap cause know they have 15psi on them , ive had coolant changed few months back.
Old car 2000/ 206 2.0 hdi.
bigtony85
PostPosted: Sun May 15, 2011 12:47 pm Up
is vehicle overheating?? or heater not working??
drive fast !!! live life faster !!!
eddrj
PostPosted: Sun May 15, 2011 12:51 pm Up
goes high in traffic dont think fans working, never overheated though no , heater is working yeah.
Just gone out and its still hissing at me lol like a snake coming from coolant tank notice it when been for a drive then get back look under bonnet and hear it .
bigtony85
PostPosted: Sun May 15, 2011 12:58 pm Up
sounds like back pressuring aka head gasket probably
cartoonhead
PostPosted: Sun May 15, 2011 1:02 pm Up
have you bled it by the 2 bleed places ?
eddrj
but the oil and coolant are fine arent sluggey brown colour thought that was main symton of head gasket and no coolant leak .
I have nothing else wrong just werid air noise .
perry081064
sounds like its got a fair bit of back pressure.
could be the start of a headgasket failure, it may be worth your while having it checked at a garage to see if gasses are present in the cooling system, also check the coolant for oil in the mixture.
206 2.0 HDI
eddrj
PostPosted: Sun May 15, 2011 1:03 pm Up
Not sure ,my mechanic did it so i duno about the bleed srews
bigtony85
PostPosted: Sun May 15, 2011 1:07 pm Up
get the coolant sniff checked. the coolant and oil dont need to b sludgy to mean a blown headgasket.
eddrj
PostPosted: Sun May 15, 2011 1:08 pm Up
coolant sniff ?? also thought loss of power is a sign and goes well the same
cartoonhead
PostPosted: Sun May 15, 2011 1:11 pm Up
there's 2 bleed places.
one is at the front and there's another thats on the pipes that go to the heater matrix
( next to brake servo , round black plastic thing with a slot for a screw driver )
bigtony85
like perry said they test for gasses in the coolant. with a blue fluid in a tube if it turns bright yellow/green there is a head gasket fault dont have to b down on power ether.
perry081064
PostPosted: Sun May 15, 2011 1:12 pm Up
eddrj wrote:
coolant sniff ??
garage will put a special mix into a tubey type thing and suck the mixture.
( if it turns dark blue , bend over and pass him the vasaline Wink )
206 2.0 HDI
perry081064
PostPosted: Sun May 15, 2011 1:13 pm Up
sorry my mistake ... green Embarassed
206 2.0 HDI
eddrj
PostPosted: Sun May 15, 2011 1:14 pm Up
ok there are the 2 bleed places,
what do i do and how much do i turn them i havent got a clue lol soz .
Ok il get my mechnic to take a look at it
Page 1 of 4
