Latest: Kifi69
Overall: 17183
Online Now [444]:
Visitors: 443
Today: 111277
Total: 144570966
Forums › The Car › 206 Talk › Air , hissing noise coming from coolant tank
Forum Index › 206 Talk
eddrj
PostPosted: Sun May 15, 2011 1:36 pm Up
ok with cap on off what ? i aint gotta clue
so just bleed them screws do and nothing else ??
Old car 2000/ 206 2.0 hdi.
bigtony85
PostPosted: Sun May 15, 2011 1:37 pm Up
i ve always wondered y there's a horse tied up out side my local pug dealer lol
drive fast !!! live life faster !!!
eddrj
PostPosted: Sun May 15, 2011 1:39 pm Up
lol they main stealers just there to cause more problems and rip people off
eddrj
PostPosted: Sun May 15, 2011 1:41 pm Up
so its that easy just bleed screws anything else gotta do while im doing that or thats it ?
radiator cap off /on ?
bigtony85
not 100% sure on a pug. but on all the trucks i hav had to coolant bleed leave cap off, engine running and unscrew the bleed screw/screws untill there is no air hissing out of them and just coolant then close them bk up. do it with a stone cold engine tho to avoid scalding yourself
cartoonhead
PostPosted: Sun May 15, 2011 1:44 pm Up
this is the matrix bleed screw
eddrj
ok il have a go cheers, so engine running and cap off
eddrj
PostPosted: Sun May 15, 2011 1:45 pm Up
ok il, try that one then till air has gone hopefully can i do with engine off or have to be engine running ?
cartoonhead
PostPosted: Sun May 15, 2011 2:00 pm Up
engine running / ticking over .
if nothing come's out leave it open till water appears or if waters there straight away close it and try the next one Smile
bigtony85
PostPosted: Sun May 15, 2011 2:06 pm Up
eddrj
PostPosted: Sun May 15, 2011 2:13 pm Up
did it noise has gone but bit of coolant water came out do i screw it back up tight again went for a drive not making hissing noise like last time
cartoonhead
PostPosted: Sun May 15, 2011 2:20 pm Up
did you drive with any of the bleed points open Shocked
open-check for air then close then check the next one , when both have been checked have a look at the water level in the water bottle , top up if need be , then test drive
eddrj
PostPosted: Sun May 15, 2011 2:23 pm Up
no well wasnt real tight bit water came out made sure it shut now properly .
Least not making stupid hissing noise thats done it only thing i find it impossible to check coolant level really do ?
cant seem to find other bleed screw but if noise has gone then should be ok getting dark now anywayz
cartoonhead
PostPosted: Sun May 15, 2011 2:26 pm Up
as tight as you can get them by hand will be ok.
eddrj
PostPosted: Sun May 15, 2011 2:32 pm Up
holy s**t na is still making flipping noise
wasnt straight after like before il check other one tmoz if i can find it and how do you see through coolant because i find it well hard almost impossible to see the level duno how much coolant i lost probably only tiny bit
Page 3 of 4
