Latest: jackrox1992
Overall: 17186
Online Now [486]:
Visitors: 485
Today: 157667
Total: 148101094
Forums › The Car › 206 Problems › WTH seriously...
WTH seriously...
Go to page 1, 2, 3  Next
karimali831
PostPosted: Tue May 17, 2011 3:57 pm Up
Only today, why why is it doing this to me?
1) Stereo working, turn off engine, returned to car, engine on, stereo won't come on.
2) Got it checked out, fuse blew up somehow (under dashboard), got new fuse.
3) Connected fuse, stereo works, parked car, turned off engine, return, the battery no longer illuminates, stereo don't work, fuse blew up again.
4) went to garage charged £30 for new wiring and new fuse where bonnet is. (they laughed about me having a small fuse for 1000 watt subwoofer, apparently I should of burnt away with the car)
5) anyway I drive home, all good. Returned to car, stero settings do not save (once again), swapped red and yellow wire as mentioned BEFORE and the CD player will NEVER come on if I swap them. it must be red and red and yellow and yellow for cd player to come on but settings DO NOT save.
what is strange is in its present state, when I turn on the battery the stereo will come on only sometimes. WHAT IS GOING ON! I'm soo annoyed.
206 GTI 180
mattievrs
PostPosted: Tue May 17, 2011 4:02 pm Up
what year is the car?
NO LONGER ACTIVE ON THE FORUM
karimali831
PostPosted: Tue May 17, 2011 4:44 pm Up
1999, I think they changed the wiring around... if I switch red and yellow radio don't work?
206 GTI 180
roberto.f
PostPosted: Tue May 17, 2011 4:58 pm Up
I'm no expert on wiring ICE, but I have done a fair load of it and I have never wired anything in the same way as that picture. What's going on there?
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
karimali831
PostPosted: Tue May 17, 2011 5:06 pm Up
It looked like this before:
imageshack.us/m/508/16...011463.jpg
They said it was completely wrong so they changed it all, not sure what does what now but I know the black wire is connected to the amp. If I change it back to the how it was in the image it won't work it will only work with the red wire in as shown:
Never had problems with this before.. why would the stero only "sometimes" come on?
206 GTI 180
roberto.f
PostPosted: Tue May 17, 2011 5:27 pm Up
I can't work out why the blue wire is connected to the 12v ignition feed. Your blue wire is the power antenna wire, that should go directly into the headunit via the connector.
It's difficult for me to work it out, but the fact that it won't turn on is probably something to do with the amp feed, ignition feed and antenna feed all connected. Most likely the reason your fuse keeps going.
I'm sure someone else will jump in with more helpful advice.
roberto.f
PostPosted: Tue May 17, 2011 5:30 pm Up
If someone else had done this and it were me, i'd buy a new Iso connector leads, plug it all in. Take your amp remote on feed from the correct wire (think it's light blue). Make sure the right amp fuse is in. If the power settings are not saved, switch the red and yellow.
evil_frogy
PostPosted: Tue May 17, 2011 5:32 pm Up
What the heck is what the red additional connection to the remote wires?! Im sure thats not meant to be there :S
I've never seen that done before and my wiring in the 206 currently is a bit weird!
What radio do you have?!
Corsa B 1.2
206 2000- GLX 1.6
A mob scenes forming....
roberto.f
PostPosted: Tue May 17, 2011 5:51 pm Up
Yeah that's what i was saying. If the black wire leads to the amp, and the blue wire is the remote wire, just cut the red wire (circled) and eleccy tape it up. It should work like that, but i would wire it again properly.
MrrNoName
PostPosted: Wed May 18, 2011 12:50 am Up
take it back to the garage, say its not working, say that its very strange the blue is connected to the power feed?!? ask them why and get them to fix it lol
Jay794
PostPosted: Wed May 18, 2011 1:36 am Up
I would have laughed at you too for having a small fuse, it's a wonder it didn't blow sooner.
Sounds like you got a ghost in the machine
devman
PostPosted: Wed May 18, 2011 2:48 am Up
When I picked up my Pug last week, my first port of call was to be sorting the stereo out. It'd obviously had an aftermarket stereo in at some point (had a quick release wiring block in the boot for an amp, and custom door builds up front), but the standard Pug CD player up front.
The standard CD player had a mind of its own. It only worked with the engine running, and the battery charging light was illuminating dimly on the dashboard. I went through all the fuses, and found a 10A one to be missing (next to the stereo fuse - though the fuse number I forget off the top of my head).
I replaced this, which knocked out the battery charging light, but now my stereo was losing its memory. Very annoying having to enter a code and search for a station every time I started the car, so ripped the stereo out to see what was happening (and fit my own Alpine unit).
What a mess. Considering how well the rest of the ICE was fitted, I cant believe what a state the wiring was behind there. Wires twisted round other wires, blue amp wire poked in the LIVE hole on the connector block! I just ripped the lot out, worked from the Pug ISO connector with a circuit tester to see what was what and rewired from there. I've fitted the blue amp wire to the correct signal wire out the back of the stereo, and all seems tickedy boo. I might try and get a guide up - still got the back end speakers to wire up so its all gotta come out again!
2000 206 2.0 HDi China Blue
1997 Jaguar XJ6 3.2 Sapphire Blue
karimali831
PostPosted: Wed May 18, 2011 3:42 am Up
is anyone willing to edit
imageshack.us/m/600/84...011464.jpg
and show where goes where? I'd appreciate it a lot... going back to garage is second thought but is a journey.
P.S. it is a KD-R301 JVC.
206 GTI 180
devman
PostPosted: Wed May 18, 2011 4:33 am Up
The picture is confusing me to be honest, as none of the pins on the ISO appear to be in the correct place....
www.uwebdesign.co.uk/i...wiring.jpg
The above link shows where the wirs should be on an ISO block...and your are nothing like it....they seem to all be in reverse....though the numbering is correct!?
From what I can see, i'd say -
Blue/White from stereo - Black Amp Lead
Yellow from stereo - Number 7 on ISO block
Red from stereo - Number 4 on ISO block
Black from stereo - Number 8 on ISO block
Orange from stereo - Number 6 on ISO block.
karimali831
PostPosted: Wed May 18, 2011 5:05 am Up
I remove the red additional connector (circled) so it's free but stereo will flash only for a second when it's on?
206 GTI 180
Page 1 of 3
