Online Now [715]:
Visitors: 714
Today: 221800
Total: 146676673
Forums › The Car › 206 Problems › Running on 3 cylinders
imjeeves
PostPosted: Tue May 17, 2011 12:59 pm Up
Just fitted my new engine after the last one let go when an oil pipe came off.
Took it testing on Sunday but it seems to be running on 3 cylinders. At tickover there is no problem sounds ok.
With a light throttle the engine missfires but as soon as a reasonable throttle is applied it clears.
The car still feels fast as it used to but the missfire is annoying. Any ideas on what it could be?
MrrNoName
PostPosted: Tue May 17, 2011 2:39 pm Up
spark plugs? were NGK used? they are bad
coil pack?
macj
PostPosted: Wed May 18, 2011 8:47 am Up
I had this...... its usually an imbalance across the T/B`s. You can check them and try mapping out the fuelling again
