Posted: Thu May 19, 2011 5:52 am |
How do you enable/disable deadlocking?
(There are no buttons by the handbrake even though the car came with
an alarm from the factory)
Cheers.
| | ![](images/spacer.gif) |
Posted: Thu May 19, 2011 5:53 am |
Push the key fob button twice isn't it?
Posted: Thu May 19, 2011 5:54 am |
Mines the smaller button on the Fob after locking the car.
Posted: Thu May 19, 2011 5:57 am |
Key fob is the newer two-button lock/unlock type.
This is for a 2007 pug.
Posted: Thu May 19, 2011 5:59 am |
V9977 wrote: |
Cheers. |
Some 206's dont have deadlocking, are you 100% sure yours does?
| Now sold:Pug 206 1.4 Quiksilver 3dr
New car: Grande punto 1.9m-jet sporting
Team: the SillyHilly fan club
Was: monkeyboy69s Now: C-MAN | |
Tried holding it for 5 seconds or so? - OR do what CD said?
Posted: Thu May 19, 2011 6:02 am |
MrZiggerz wrote: |
Tried holding it for 5 seconds or so? - OR do what CD said? |
Thinking about it I recall holding the button.
Posted: Thu May 19, 2011 6:03 am |
CD-vRS wrote: |
MrZiggerz wrote: |
Thinking about it I recall holding the button. |
It won't get the key into the dreaded sync procedure holding it down will it?
Posted: Thu May 19, 2011 6:06 am |
V9977 wrote: |
CD-vRS wrote: |
MrZiggerz wrote: |
It won't get the key into the dreaded sync procedure holding it down will it? |
Pretty sure the key has to be in the ignition and turned 1 click to do that.
Posted: Thu May 19, 2011 6:09 am |
CD-vRS wrote: |
Pretty sure the key has to be in the ignition and turned 1 click to do that. |
Not on my single-button old style one.
C-MAN wrote: |
Some 206's dont have deadlocking, are you 100% sure yours does? |
Nope. But its for a 2007 with deadlocking solenoid locks by the looks of them.
Posted: Thu May 19, 2011 7:07 am |
you probabbly need to re sysnc the key not hard to do
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Thu May 19, 2011 7:59 am |
leigh_boy wrote: |
you probabbly need to re sysnc the key not hard to do |
V9977 wrote: |
Cheers. |
Posted: Thu May 19, 2011 8:39 am |
mines a 53 plate, have 2 buttons on the fob one to lock and another to unlock, to deadlock my car i just press the lock button 2 times.
Posted: Thu May 19, 2011 8:49 am |
OK, cheers all.
Will try and let you know.
Posted: Thu May 19, 2011 8:53 am |
Jacko27 wrote: |
mines a 53 plate, have 2 buttons on the fob one to lock and another to unlock, to deadlock my car i just press the lock button 2 times. |
In the handbook, it says that you press the lock button once and it dead locks it. If you press it the second time within 5 seconds, it disables the deadlock. (This is on the new key type)
It also works the same way if locking by key in the door.
On older 2 button type keys, you press the pug logo button to lock, then the smaller button to deadlock.
