Latest: cogeim7
Overall: 17185
Online Now [581]:
Visitors: 581
Today: 62001
Total: 147189103
Forums › The Car › 206 Problems › WTH seriously...
WTH seriously...
Go to page Previous  1, 2, 3
Matt
PostPosted: Thu May 19, 2011 5:10 pm Up
Trade Rating: +32
No the gold ring goes onto the screw in the fuse box.
karimali831
PostPosted: Thu May 19, 2011 5:29 pm Up
Missing the point, it won't connect to the fuse like it did before causing damage, it will connect to the positive terminal.
206 GTI 180
Matt
PostPosted: Thu May 19, 2011 5:52 pm Up
Trade Rating: +32
Not really missing the point am I?
You asked where it goes, I told you.
That's where mine is and has been for nearly a year now Wink
If anything is wrong it's not that.
Try looking at that mess of wiring behind your centre console.
karimali831
PostPosted: Thu May 19, 2011 6:01 pm Up
I'm soo confused now, some are saying connect to positive terminal and some are saying connect to fuse. Here?!
imageshack.us/m/860/8324/bonz.png
That's where all the problems kicked in to begin with... I really need the correct answer!
Thanks Smile
206 GTI 180
PostPosted: Fri May 20, 2011 12:39 am Up
It don't matter if its connected to the positive pole on batt or the nut in fuse box, it's the same thing.
And why does that black wire i said about go to amp? What slot on amp??
Edit: I take it that's the remote for amp lol
MrrNoName
PostPosted: Fri May 20, 2011 1:45 am Up
What He Said
(awaits my car wont start, have i killed my ECU? thread) Razz
Matt
PostPosted: Fri May 20, 2011 3:04 am Up
Trade Rating: +32
This is a pic of mine I took this morning just for you Wink
karimali831
PostPosted: Fri May 20, 2011 6:58 am Up
Thanks a lot for this, connected as shown and all working great now Very Happy
There is just one "FINAL" minor annoying issue, the memory does not hold when battery is off and yes I swapped red and yellow but both combinations "red/red yellow/yellow" and "red/yellow red/yellow" does not hold the memory.
206 GTI 180
devman
PostPosted: Fri May 20, 2011 7:04 am Up
I'll check out my fuse combination, mine didn't work quite right till I found the right combination there either!
2000 206 2.0 HDi China Blue
1997 Jaguar XJ6 3.2 Sapphire Blue
Danny.
PostPosted: Fri May 20, 2011 8:23 am Up
Memory issue..
206info.co.uk/Forums/v...16054.html
Little bit of searching would've found that.
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
devman
PostPosted: Fri May 20, 2011 8:28 am Up
^ That's what I was going to show you, cheers for saving me a job Smile
Danny.
PostPosted: Fri May 20, 2011 8:30 am Up
No worries.. took me ages to work it using a multimeter out so made a how to a while back Smile
karimali831
PostPosted: Fri May 20, 2011 2:43 pm Up
Perfect, thank you!
But wow.. the head unit is scorching HOT I can barely touch it... is this a normal occurrence?
206 GTI 180
MrrNoName
PostPosted: Sat May 21, 2011 2:27 am Up
some do get very hot after being on for a while Razz
Page 3 of 3
