Online Now [260]:
Visitors: 259
Today: 38598
Total: 142307080
Forums › The Car › Solved 206 Problems › SOLVED! Handbrake cable/Electrical problem
Go to page Previous  1, 2
PostPosted: Sat May 21, 2011 3:29 pm Up
I aint got a fecking clue
Probaly the handbrake cable switch below, wire have come out and shorted on the body
elcamino
PostPosted: Sat May 21, 2011 3:40 pm Up
There should be a sign of spark or melted wire insulator...
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Antknee
PostPosted: Sat May 21, 2011 3:44 pm Up
im gonna have a tinker before work tomorrow so ill post up when i fix it, if not there's a guy at work who owns a garage and said he'll sort it for me for free Smile
Antknee
PostPosted: Sun May 22, 2011 2:19 pm Up
Fixed it! Very Happy
Turns out it was a dodgy earth as everyone suggested
What i done was unbolt all the earthing points (bar 1 or 2), cleaned them with emery paper and checked for broken wires while i was doing it (didnt find any), also the earth at the bottom of the LH sill seemed a bit flimsy so i put a cable from the battery -ve to the earth point, worked a treat Very Happy
thanks for all the suggestions!
Any
Antknee
Ant
elcamino
PostPosted: Sun May 22, 2011 2:21 pm Up
I was wrong then!!
Antknee
PostPosted: Sun May 22, 2011 2:25 pm Up
ah well, no worries, we cant all be right all of the time Razz
elcamino
PostPosted: Sun May 22, 2011 2:33 pm Up
Did you find any melted wire or spark sign?
Antknee
PostPosted: Sun May 22, 2011 2:36 pm Up
nope didnt see anything but some of the contacts were a bit oxidised so was probably some part of the problem
Page 2 of 2
