Posted: Sat May 21, 2011 3:29 pm |
I aint got a fecking clue
Probaly the handbrake cable switch below, wire have come out and shorted on the body
| Team Impossible Possible
Posted: Sat May 21, 2011 3:40 pm |
Addaz wrote: |
Probaly the handbrake cable switch below, wire have come out and shorted on the body | There should be a sign of spark or melted wire insulator...
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Sat May 21, 2011 3:44 pm |
im gonna have a tinker before work tomorrow so ill post up when i fix it, if not there's a guy at work who owns a garage and said he'll sort it for me for free
Posted: Sun May 22, 2011 2:19 pm |
Fixed it!
Turns out it was a dodgy earth as everyone suggested
What i done was unbolt all the earthing points (bar 1 or 2), cleaned them with emery paper and checked for broken wires while i was doing it (didnt find any), also the earth at the bottom of the LH sill seemed a bit flimsy so i put a cable from the battery -ve to the earth point, worked a treat
thanks for all the suggestions!
Any
Fixed it!
Ant
Posted: Sun May 22, 2011 2:21 pm |
I was wrong then!!
Posted: Sun May 22, 2011 2:25 pm |
ah well, no worries, we cant all be right all of the time
Posted: Sun May 22, 2011 2:33 pm |
Antknee wrote: |
ah well, no worries, we cant all be right all of the time | Did you find any melted wire or spark sign?
Posted: Sun May 22, 2011 2:36 pm |
elcamino wrote: |
Antknee wrote: |
ah well, no worries, we cant all be right all of the time | Did you find any melted wire or spark sign? |
nope didnt see anything but some of the contacts were a bit oxidised so was probably some part of the problem
