Latest: Kifi69
Overall: 17183
Online Now [492]:
Visitors: 492
Today: 94193
Total: 144112040
Forums › The Car › 206 Talk › new battery rating?
new battery rating?
qwert
PostPosted: Mon May 23, 2011 6:22 am Up
hi,
im in the need of a new battery as the car is struggling to start. Ive read a varta battery is the way to go. Which one do i need...56ah, 60ah, 61ah, or 63ah.
The car is a 2:0 hdi
thanks
brum brum
PostPosted: Mon May 23, 2011 6:56 am Up
PostPosted: Mon May 23, 2011 3:56 pm Up
Varta D15 Silver Dynamic is the one you want.
Look out for the Bosch equivalent if its cheaper.
Varta make the batteries for Bosch so there exactly the same under the stickers Wink
PostPosted: Mon May 23, 2011 4:41 pm Up
Total overkill IMHO:
PostPosted: Mon May 23, 2011 4:46 pm Up
why over kill?
diesel need more power to start the engine compare to petrol.
i use the same battery as well (bosch S5)
PostPosted: Mon May 23, 2011 4:51 pm Up
Seabook wrote:
why over kill?
Is it the glow-plugs or more cranking power needed?
PostPosted: Mon May 23, 2011 4:57 pm Up
glow plugs don't normally kick in unless very cold (negative degree or close to zero)
is just it need more cranking power due to higher engine compression
PostPosted: Mon May 23, 2011 5:02 pm Up
Ah OK, we only have taxis over here which are diesel.
Not allowed for passenger cars at all, so not much experience on that.
Still think its a bit of an overkill for a 206 TBH.
PostPosted: Mon May 23, 2011 5:07 pm Up
Why?
Starts my TU3 powered 206 whatever the weather Wink
Cheap enough, 5 year warranty & plenty of extra power in reserve Cool
PostPosted: Mon May 23, 2011 5:16 pm Up
MrBSI wrote:
Why?
Because I've been running a Black Dynamic for years and never had
the slightest issue even at very low/extremely high temps.
Unless you are using a substantial ICE rig I don't see the point really.
PostPosted: Mon May 23, 2011 5:24 pm Up
V9977 wrote:
MrBSI wrote:
Why?
pretty sure during winter uk should be quite a bit colder than Athens?
and you don't have a diesel anyway
short journey and cold weather=battery killer.
diesel already quite hard to start in winter even with good glow plug, longer cranking time+weak battery = Laughing
PostPosted: Mon May 23, 2011 5:42 pm Up
Up north where I go it gets quite chilly believe me (-10 C no problem).
Summer in Athens = 40+ C easy.
Since its a diesel though and a 2.0 Hdi at that, you might well be right so I'll let it lie. Razz
data
PostPosted: Mon May 23, 2011 5:50 pm Up
I use a big capacitor. It's 330,000 farads and I custom made the charging circuit. Cost a pretty penny, mind you!
Onyx Black 2005 206 GTi 180, 44K miles, FSH, standard (apart from a K&N panel air filter, Angel Eyes and groovey rear & groovey front holy discs!)
PostPosted: Mon May 23, 2011 5:52 pm Up
Are you sure its not 330000μF?
Stick one of these in aswell if you dare and tell us what treble you get.
PostPosted: Mon May 23, 2011 6:46 pm Up
what i have been remember is last winter many diesel runner on info are struggle to start their car Laughing Laughing a few threads per week! Laughing
