Online Now [555]:
Visitors: 554
Today: 141341
Total: 105867912
Forums › The Car › 206 Problems › MOT failure - Horn not working.
Go to page Previous  1, 2
Ape
PostPosted: Fri May 20, 2011 7:57 am Up
Jack the front of the car up and you can just about get to it from the front without removing any. I'm betting its a corroded connector on the claxon as my old Pug had the same problem. I could get to it without removing any trim by getting underneath and undoing the bracket it's attached to. Soldering upside down is a nightmare though Laughing
You could fix it yourself very cheaply by prodding around and having a look
MrrNoName
PostPosted: Fri May 20, 2011 8:04 am Up
also the grill clips (hog ring clips) easily break and are cheap as chips on ebay, or even not that dear from a dealer, dw about that Smile even if you need a new grill they are cheap too.
PostPosted: Fri May 20, 2011 8:07 am Up
Ive never seen the clips cheaper on Ebay.
Ive always found a Peugeot / Citroen main dealer is always cheaper Wink
clarky78
PostPosted: Fri May 20, 2011 8:16 am Up
What clips? the clips that broke on both the upper plastic and the gril are both part of the actual trim.
I realise it is probably a rusty connection, but the airbag light needs fixing and I knew it would end up at the garage for that anyway.
I hate jacking the pug up I find it impossible to get a good jacking point that doesnt result in something bending..!
Black 206 GTI 180
clarky78
PostPosted: Mon May 23, 2011 5:44 am Up
OK, Peugeot reckon it need's a new horn AND a new comm2000! That last one was fitted by this dealer in July 2009 under warranty.. Fingers crossed it still gets done under warranty, but the warranty expires in 6 days... Either way it's gonna cost me a fortune! POS car!
Black 206 GTI 180
Ape
PostPosted: Mon May 23, 2011 5:54 am Up
I'd find a local independant that can help bud. Wouldn't trust a stealer.
Jacking wise - the subframe is never a bad place to use.
clarky78
PostPosted: Mon May 23, 2011 7:27 am Up
I assume the warranty company have authorised it as I haven't heard anything since I told the dealer to ring them. If I took it somewhere else, I'd be charged the diagnostic anyway, and if it does need the com2000 I'd be no better off.
Black 206 GTI 180
meady
PostPosted: Mon May 23, 2011 9:23 am Up
Trade Rating: +45
If you need a new com2000 and horn i will have thmboth for sale Smile
TEAM - I HATE FACEBOOK Smile
meady
PostPosted: Mon May 23, 2011 9:25 am Up
Trade Rating: +45
PostPosted: Mon May 23, 2011 9:49 am Up
Depends who did it...
clarky78
PostPosted: Mon May 23, 2011 11:39 am Up
Well warranty is paying so it should cost me about 150 for the lot fitted. if it's fixed thats all that matters.
Black 206 GTI 180
Page 2 of 2
