Latest: jackrox1992
Overall: 17186
Online Now [1098]:
Visitors: 1098
Today: 11640
Total: 148781120
Forums › The Car › 206 Problems › please help!
please help!
chief93
PostPosted: Tue May 24, 2011 6:27 am Up
i have a 2005 peugeot 206 1.4 hdi with 73,000 miles on the clock. and as of last night it has very little too no power what so ever until the turbo kicks in at about 2000 revs. i know they do this a bit anyway but not as drastic as this. im no mechanic so im just asking the advice of anyone on here. however i do know the clutch is on its way out as that has been slipping when you go to put your foot down is this the problem\/ like i say it just suddenly went really bad last night thanks
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
panason1c
PostPosted: Tue May 24, 2011 7:14 am Up
You've diagnosed your own problem really, the slipping clutch is the reason for what you perceive as 'no power'
Once the clutch starts slipping it very quickly deteriorates to a 'badly' slipping clutch to no drive whatsoever.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
chief93
PostPosted: Tue May 24, 2011 3:03 pm Up
im not 100% sure it is the clutch though because its not lsipping at low revs and if you go to put your foot down literally nothing happens it builds up ever so slowly but i mean at snail pace it was only slipping after the turbo comes in. its just werid it happend all of a sudden because the clutch has been slipping odd times since october
PostPosted: Tue May 24, 2011 3:19 pm Up
did the rev goes up when you flooring it?
chief93
PostPosted: Wed May 25, 2011 3:30 am Up
before the lack of power happend it would yes once it got to a certain amount of revs but now it isnt.
Barking
PostPosted: Wed May 25, 2011 3:40 am Up
those smiley avatars are doing my head in Laughing
I got a dig bick.
You that read wrong.
You read that wrong too.
Norvvv
PostPosted: Wed May 25, 2011 3:49 am Up
Fix the clutch, then you'll know. You need to do the clutch anyway as mine started slipping and then completely went later the same day.
2001 1.4lx
PrePlexed 5 door.
chief93
PostPosted: Wed May 25, 2011 9:48 am Up
yh its booked in for next wednesday so i'll just nurse it till then
chief93
PostPosted: Sun May 29, 2011 2:28 am Up
its not the air filter, and the fuel filter has been replaced coem on guys someoen must no whats causing it? could it be the fuel pump? or maybe the solenoid
