Online Now [384]:
Visitors: 384
Today: 164294
Total: 146619187
Forums › The Car › 206 Problems › 206 1.4 sport 55 plate
Go to page Previous  1, 2
abs06
PostPosted: Wed May 25, 2011 4:40 am Up
Oh sorry. Knew it was either onr i said or the long black one. Have a sport model too Smile
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Wed May 25, 2011 5:14 am Up
kieron wrote:
MrBSI wrote:
davidt wrote:
plugs and plug leads?
What leads its a 206 they dont have HT leads Wink
Bosch OR genuine Peugeot / Citroen Eyquem spark plugs only! DONT fit NGK plugs to a PSA engine as they are known to cause problems / damage engine ecu's!
Is this a proven fact tho? my GTI had a full service at kwik fit and ngk was fitted
i hear loads of people say ngk will damage the coil pack etc but ive seen a few 206s that have had them in for year without any problems at all
if this is the case ill get mine removed asap
Ask your local Peugeot / Citroen main dealer, maybe they will show you the technical service bulletin PSA Peugeot / Citroen sent out to its dealer network warning about NGK plugs & the problems they cause.
davidt
PostPosted: Wed May 25, 2011 1:44 pm Up
thanks all, its booked in with a garage for a look
service items first
Early days
PostPosted: Wed May 25, 2011 1:48 pm Up
Is there any fault codes?
davidt
PostPosted: Wed May 25, 2011 1:58 pm Up
Is it possible to check for fault codes DIY or does it need a garage?
Early days
Page 2 of 2
