Posted: Tue May 24, 2011 10:29 am |
MrBSI wrote: |
All 206 wipers go the wrong way. |
Why is this? I've always wondered lol.
Posted: Tue May 24, 2011 10:43 am |
Mike_XS wrote: |
MrBSI wrote: |
Why is this? I've always wondered lol. |
because the cars french which are left hand drive
if you look under the dash in the passenger footwell you'll also see the brake servo to prove how lazy peugeot was
Posted: Tue May 24, 2011 10:45 am |
ExoVyper wrote: |
Mike_XS wrote: |
MrBSI wrote: |
if you look under the dash in the passenger footwell you'll also see the brake servo to prove how lazy peugeot was  |
Yeah, I understand that. But most french cars I see, the wipers go the correct way.
Posted: Thu May 26, 2011 2:34 am |
Corsa_Alex wrote: |
Lee wrote: |
Get the tape measure out
Will either be 19/26 or 22/22 |
i thought everyones saying 22/22 is too big and over hangs the windscreen and should be 21/21 ? |
can someone confirm this =(
i believe mine are the original wipers, bosch is it?
the wiper frame itself is 21" but the blade refills fitted for me measure out as 22".
for these awesome aero twins. 22 or 21?
Posted: Thu May 26, 2011 2:48 am |
I've ordered a set of 21" from the ebay link provided, I'll let you know how they fit!
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Thu May 26, 2011 2:54 am |
i just purchased a set of bosch areo twins both 22" and they fit on the windscreen fine, due to the high curvature of the screen in the very corner of the divers side the blade doesnt wipe effectivly, but this is only in the very corner (the extra 1inch basically), the wipers do not hang over the windscreen at all, 22 is the correct size. but the only advantage you get to having 22" is that the passenger size has 1" more of wipeage lol. you get the same wipeage on a 21 and a 22 inch blade on the drivers side because the blade lifts off (due to curvature) at the very edge.
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Thu May 26, 2011 3:02 am |
im starting to think it is 22".
just went to auto lites site to have a look and the wiper kit for peugeot 206 is a 22".
so are those on ebay. 22". AR530S is the model i think.
ahhhhhh
Posted: Thu May 26, 2011 3:03 am |
to be fair like I said both the 21 and 22 inch blades give you exactly the same wipeage on the drivers side, and the 22 inch blade gives you 1inch more on the passenger side, it basically makes no difference
Posted: Thu May 26, 2011 3:10 am |
hell, i'll just buy them off auto lites and get over with it !
Posted: Thu May 26, 2011 3:16 am |
21 or you will be regraded.
