Latest: Kifi69
Overall: 17183
Online Now [455]:
Visitors: 454
Today: 89747
Total: 144549524
Forums › The Car › 206 Problems › engine over heating when turnd off
omricn
PostPosted: Wed May 25, 2011 10:57 pm Up
Hy everybody, i'll cut to the chase:
It took me a while to get used to the temperature changes in my 206 but i was told everything is okay and that this is a normal thing for a pug to do (70 deg on a highway, 90-100 in the city).
When i get home\to work etc. and park with engine running the temp will start rising until it'll hit 102 degrees and then the fan will come on and lower the temp to about 90, BUT if i turn the engine off the fan will not come on and i can see the temp rising allmost to the red area Shocked ..
Now allot of 206xsi owners have told me that this is a normal behavior, but it just doest seem right to me..
by the way i live in a warmish country and the summer just hit us.
p.s. could it be that i dont have a thermostat at all?..
Danny.
PostPosted: Thu May 26, 2011 1:35 am Up
You dont have a thermostat? o.o
Get one.
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
JE_180
PostPosted: Thu May 26, 2011 1:49 am Up
Get one.
I think that was him asking if it was possible to not have one lol
omricn
PostPosted: Thu May 26, 2011 1:57 am Up
john_e88 wrote:
Get one.
Yeh exactamoly, but i don't think that is the matter, as a friend of mine with an XSi also reports a similar behavior, i'm just looking for a confirmation from you guys..
Quarmbo
PostPosted: Thu May 26, 2011 2:30 am Up
Flick your a/c on, it'll bring it down if you're that worried.
Ford SportGay-A
omricn
PostPosted: Thu May 26, 2011 2:34 am Up
Hy, i'm quite aware of that trick, but there's no need for it as my fan will work if the engine is running, but will fail to turn on if the engine is off, is it possible that i just jave a faulty connector or unit that triggers the fan once the engine is off?
omricn
PostPosted: Thu May 26, 2011 3:26 am Up
Ok so after i did ome digging up and asked some friends, i think i'v got it, i believe the relay that is supposed to turn on the fan when the engine is off is not doing it's job and should be fired and replaced with a better employee.
I'll also check the relays that are ment to control the fan speeds, there should be two fan speeds as i understand, low and high, donnow if they're working.
glenpring
PostPosted: Thu May 26, 2011 3:48 am Up
i dont think any fan will turn on when the engine is off when i turn my 307 off everything stops? or am i missunderstanding what your saying Embarassed
omricn
PostPosted: Thu May 26, 2011 3:55 am Up
Well my dear friend I can see you're from the UK, i dont think temperatures there reach up to 35° Celsius (95° Fahrenheit) Wink they do here.. and with that kind of climate - the fan will work overtime.
And on that note - i envy you (though i like a good summer day too Smile )
ukskater01
PostPosted: Thu May 26, 2011 3:56 am Up
My non air con 1.1 will keep the fan going but on a very low speed if it was running before I turn the engine off, not sure if it's different on air con models?
omricn
PostPosted: Thu May 26, 2011 4:05 am Up
Thats great, it means it's working like it should, like I want it to work in my 206, what you just described tells a couple of things -
1. your low speed fan unit\relay is working fine
2. your "engine off fan control" unit\relay is working fine
good for you Smile
ukskater01
PostPosted: Thu May 26, 2011 4:09 am Up
Indeed good for me! Wink
