Latest: Stu-mill
Overall: 17131
Online Now [70]:
Visitors: 70
Today: 4989
Total: 104892646
Forums › The Car › 206 Problems › Weird Brake Light Problem
PostPosted: Sat May 28, 2011 11:42 am Up
Ah OK.
Then you're connecting is series to drop the current.. 1W should be fine and no heating.
18 Ohms sounds way too low.. Should be 1.8K or 180 Ohms at lowest I would think.
Can you check the other ones?
PostPosted: Sat May 28, 2011 11:44 am Up
Other ones are fine. They are all the same. Had the brake light fitted 2 years, and its just gone.
Ironically, one blew in that, and one went in my front lights. Not having any look with electrics on the car recently. Had to get a new battery last week as well Laughing
PostPosted: Sat May 28, 2011 11:45 am Up
Wait a minute, it is 180 Ohms = Brown-grey-brown my bad!
Could need 1.8K, check the others if you can.
I still think the switch is probably gone though.
PostPosted: Sat May 28, 2011 11:48 am Up
Yeah I think it probably is.
As even with the third brake light disconnected, I'm still getting the same voltage. Makes me wonder if some water got on the connector and it shorted it.
PostPosted: Sat May 28, 2011 11:50 am Up
Wouldn't think so that quick..
Anyway I hope you sort it mate. No brake lights is considered bad, even over here. Shocked
PostPosted: Sat May 28, 2011 11:52 am Up
Yeah, not the best lights to not have working Laughing
Bank holiday as well, so nothings open till Tuesday Twisted Evil
PostPosted: Sat May 28, 2011 11:54 am Up
Hope the loom is OK.
PostPosted: Sat May 28, 2011 12:27 pm Up
Loom I'm not overly fussed about, because I can easily rewire that, only half a dozen wires.
And if worse comes to worse, I have a spare cabin loom anyway.
PostPosted: Sat May 28, 2011 2:28 pm Up
I believe what caused your problem was a short circuit cause by the 3rd brake light when you refitted it,maybe you got a "naked" wire somewhere...hehe,check for it,the heat in wires is always cause by a short.
PostPosted: Wed Jun 01, 2011 5:13 am Up
Any luck with this yet Lee?
PostPosted: Wed Jun 01, 2011 11:05 am Up
Yeah fixed it.
Just rewired it all Smile
Took about 30 mins Smile
PostPosted: Wed Jun 01, 2011 11:45 am Up
Lee wrote:
Yeah fixed it.
Cool.
Quick question:
I have one of these fitted for the past couple of years and works a treat.
However, I'm now thinking of replacing the 501's with LED's so as to set it on fast mode (strobe) which will look a bit neater (see video).
Will need a droping resistor, but which of these are better for a standard 3rd light unit?
1) cgi.ebay.com/ws/eBayIS...K:MEWAX:IT
2) cgi.ebay.com/ws/eBayIS...K:MEWAX:IT
3) cgi.ebay.com/ws/eBayIS...MEWNX%3AIT
PostPosted: Wed Jun 01, 2011 12:01 pm Up
The standard one uses white bulbs I think, rather than red bulbs.
Think these could be ok - cgi.ebay.com/ebaymotor...ccessories
As you would be better off with completely forward facing ones, rather than having some light coming out of the sides of the bulb/led
PostPosted: Wed Jun 01, 2011 12:14 pm Up
I look into it. Thanks.
P.S. I bet you can't fit that flasher in the UK without getting in trouble.
PostPosted: Wed Jun 01, 2011 12:20 pm Up
It would be fine I think Smile
This is my latest mod Laughing - www.youtube.com/watch?v=DSJHxBjJ9pM
Page 2 of 3
