Online Now [1014]:
Visitors: 1013
Today: 11333
Total: 146466295
Forums › The Car › 206 Problems › fan belt wont fit
fan belt wont fit
dumdum0910
PostPosted: Sat May 28, 2011 4:49 pm Up
i am on my 2nd fan belt . i got this 1 from peugeot but i cannot get it to go over the tensioner. i pull it back all the way with a spanner but it seems to short, but when i put it up against the old 1 its the same Confused peugeot say there is only 1 length for this engine. any ideas? ive tried soaking it in hot water to try and soften it up
i have a 1.1 look
nakednakeddave
PostPosted: Sat May 28, 2011 5:56 pm Up
put a 3/8 ratchet with a bar in the hole next to the tensoiner when the belt of almost in the right position and pushe the ratchet and should move enough to slip on.
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
dumdum0910
PostPosted: Sun May 29, 2011 3:49 am Up
what hole do you mean? i cant see any hole? Confused
dumdum0910
PostPosted: Sun May 29, 2011 4:24 am Up
were would this hole be? the top tensioner is the 1 you put a 13mm spanner on to move the tensioner in and out
richpowell91
PostPosted: Sun May 29, 2011 5:11 am Up
Do you have an automatic tensioner or a manual tensioner? If you have an automatic tensioner then there will be a square hole to the left of the roller pictured.
www.peugeot206cc.co.uk...htm#DEPOSE
there's a good guide, the bottom picture shows the hole if it has an automatic tensioner.
dumdum0910
PostPosted: Sun May 29, 2011 5:20 am Up
www.peugeot206cc.co.uk...-k06sc.gif its this 1 but it doesnt have the spring between the tensioner and crankshaft pulley
dumdum0910
PostPosted: Sun May 29, 2011 5:30 am Up
also i dont have any adjuster on the alternater Confused
richpowell91
PostPosted: Sun May 29, 2011 5:40 am Up
Ah okay sorry ignore all that then, have you tried putting the old on back on again to make sure there isnt a problem with the tensioner?
dumdum0910
PostPosted: Sun May 29, 2011 5:41 am Up
yep got the old 1 on. the old 1 goes straight on with no problem so im confused.
PostPosted: Sun May 29, 2011 5:42 am Up
That is impossible,it's a must,and do as the guys said above,other wise the belt would be lose,and slip out while you drive,it have to be tight to work well.
dumdum0910
PostPosted: Sun May 29, 2011 5:44 am Up
the top tensioner is spring loaded . the alternator is bolted straight on to the block
PostPosted: Sun May 29, 2011 5:57 am Up
i have a 1.1 look
Firstly do you need two threads for the same problem?
Secondly, if they used your chassis number then there will only be one belt to fit your car.
And I've just emailed you a guide to your msn address
