Online Now [382]:
Visitors: 381
Today: 135888
Total: 144956053
Forums › The Car › 206 Problems › GTi 180 clutch
GTi 180 clutch
sri16v
PostPosted: Mon May 30, 2011 11:21 am Up
Hi , my GTi 180 has developed a nasty judder on the bite point, and also the release bearing is getting noisier by the day.
Im going to replace the clutch but whats the best one to go for or will any make do?
Any things I should know about doing a clutch on a 180 or is it as straightforward as any car?
Also Im guessing the judder may be down to the flywheel, should I bother changing the flywheel or leave it as it is.
thanks
2004 GTi 180
PostPosted: Mon May 30, 2011 11:22 am Up
Clutch judder on a 180 is a common problem Wink
LUK, Sachs or Valeo for the clutch kit.
sri16v
PostPosted: Mon May 30, 2011 1:00 pm Up
Dont I know it, its always had a judder, but it has got a lot worse and with the release bearing making an ever increasing noise I cant see the clutch surviving much longer. Can feel the vibration through the pedal when just resting my foot slightly on the pedal.
bit annoyed as my old Gti made it to 93,000 miles before requiring a clutch, where as the 180 has only just hit 53,000 and I need rid, but may have to keep a bit longer now.
Is the clutch change any different on the 180 to the GTi?, anything I should be aware of or is it a straightforward job?
Any idea of the price of a clutch kit?
2004 GTi 180
leigh_boy
PostPosted: Mon May 30, 2011 2:25 pm Up
alot of people say about checking the fly wheel as that causes the judder as it warps
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
L18LTM
PostPosted: Mon May 30, 2011 2:32 pm Up
check the fly wheel to, if you change the clutch without checking nd the flywheel is warped it will kill your new clutch as well
Dream As If You'll Live Forever, Live As If You'll Die Today Smile
