Latest: jackrox1992
Overall: 17186
Online Now [727]:
Visitors: 726
Today: 155297
Total: 148680347
Forums › The Car › 206 Problems › AAAARRRRGGHH!
AAAARRRRGGHH!
rudymason
PostPosted: Wed Jun 01, 2011 6:57 am Up
ok so just bought a few things from the scrappy, new dials which dont work as there are two plugs in the back of the new one (black fascia) and mine only has one plug(white fascia) so first thing im wondering is there any way of adapting the new one to the old one Smile
Secondly bought a gti steering wheel for a fiver its in wicked nick but dont think itll fit mine as i havent got mine off yet but where the 2 holes to remove the airbag from the new one are , there arent any on mine, does this mean there's no way to fit it??
Thanks for any info and advice Smile
iainlovatt
PostPosted: Wed Jun 01, 2011 6:59 am Up
no to the first one, and what plate is your car on?
(My Garage)
rudymason
PostPosted: Wed Jun 01, 2011 7:01 am Up
its an 04 1.4 S model and is multiplexed Smile
Also so my only oprtion would be to swap the fascias and dials??
rudymason
PostPosted: Wed Jun 01, 2011 7:10 am Up
and also is it possible to have an adapter to use gti autofolding mirrors on a non gti?? if not how can it be done??
PostPosted: Wed Jun 01, 2011 7:17 am Up
What year was the car you removed it from? preplex is pre 2001 so if it was before then then the steering wheel will not fit.
Yes it is possible but it requires a lot more work than a adapter
rudymason
PostPosted: Wed Jun 01, 2011 7:22 am Up
the one i took it from was a 03 plate gti , it had all the sp stuff etc so i would thought it would be the same :S and ok what else do you need is it the switch to enable you to autfold them ??
PostPosted: Wed Jun 01, 2011 7:25 am Up
Then they will both have the clip on airbag type so will fit. Unless you get pictures can't really help anymore.
I don't know I haven't done it myself but yes you need the switch and a fair bit of wiring if I remember correctly.
rudymason
PostPosted: Wed Jun 01, 2011 7:37 am Up
k brilliant , so even though on the back of the gti one there are two screw holes that hold in the airbag and on mine there arent , the connections should still be the same and it should be fine??
iainlovatt
PostPosted: Wed Jun 01, 2011 8:07 am Up
no mate unfortunately it doesn't work like that! Very Happy
(My Garage)
PostPosted: Wed Jun 01, 2011 9:05 am Up
Bolt on airbags are pre 2001 and after are clip on you NEED the correct one. I don't understand how you got a bolt on steering wheel from an 03 car. Did it have an airbag? Do you have any pics to confirm? Would help a lot
meady
PostPosted: Wed Jun 01, 2011 9:13 am Up
Trade Rating: +45
For the auto folding wingmirrors basically you need to wire thm in ( cut the plug fom your car and the mirrors and wire together) i done this to mine and they worked a treat. Plus i have the mirrors for sale of intrested with the switch. Cheers
TEAM - I HATE FACEBOOK Smile
rudymason
PostPosted: Wed Jun 01, 2011 10:01 am Up
Do you mean am i interested in the mirrors with the switch?? if so errrm i dont know right now ill pm you and also what dop you mean just cut and wire them together?? do mean use the existing wires but dont wire the wires for the autofolding part and they will then work the same as old ons???
cheers
also thanks for everyones help Smile
rudymason
p.s i would get pics up but cant find my camera Neutral and my phone leads over the mrs Sad
meady
PostPosted: Wed Jun 01, 2011 10:58 am Up
Trade Rating: +45
don't wory ive just noticed tht u have a newer car so wouldnt need to do tht. Igbore what i said. Cheers
rudymason
PostPosted: Wed Jun 01, 2011 12:52 pm Up
k cool no worries, well anyways ive had a look around n it looks like it aint gonna fit so yeah i got one for sale and ill be putting it up on ebay shortly Wink anywho fitted all the other stuff i got from scrappy today inc sp pedals, vents , handbrake , door handles and fuel cap must say i never thought itd make that much of a difference!! also fitted half leather seats in back , got the front ones just they need a little more tlc Wink but looking good hehe!!
