Online Now [468]:
Visitors: 467
Today: 95524
Total: 146994004
Forums › The Car › 206 Talk › Fixed one problem, gained another...
Forum Index › 206 Talk
Mike_XS
PostPosted: Wed Jun 01, 2011 2:05 pm Up
Did my brake pads this evening when I got home from college. Was a bit fiddley but got it done ok.
As I was finishing the drivers side I noticed the shock is leaking. So that's another job to add the list. New front shocks.
Bad times.
ukskater01
PostPosted: Wed Jun 01, 2011 2:14 pm Up
I know how you feel, my exhaust rotted and started rattling, then my rad started leaking and my fan needed to be replaced, I got this done and a day later I got a puncture and my spare was screwed!and I need my front left shock looking at as it squeaks. Starting to regret buying such an old car!
Rant over! Suppose that's what you get for buying French
PostPosted: Wed Jun 01, 2011 2:16 pm Up
cheap fix if you can diy.
Mike_XS
PostPosted: Wed Jun 01, 2011 2:17 pm Up
Lol yeah. I'm in quite a ranty mood at the moment. My locks are bouncing now and I can't figure our which one is at fault. My car is 11 years old now though. And these are the first problems in 2 years of owning.
Mike_XS
PostPosted: Wed Jun 01, 2011 2:18 pm Up
I will be doing it myself. What do you think is my best option? Getting 2nd hand from a scrappy? Or buying new?
PostPosted: Wed Jun 01, 2011 2:31 pm Up
i would always use new parts. except body panel Laughing
Mike_XS
PostPosted: Wed Jun 01, 2011 3:20 pm Up
How much do you reckon roughly?
PostPosted: Wed Jun 01, 2011 3:28 pm Up
good oem/ bilstein dampers should be around 50 to 60 each.
stu_gti180
PostPosted: Wed Jun 01, 2011 3:32 pm Up
problems always come at once dont they..... so far
New driveshaft, both front lower wishbones, full new clutch and release bearing, vvt solenoid needs changing (only replaced 2 yr ago), both front tyres and now to cap it off drop links need changing.
Gti 180, 04, Janspeed cat-back system, viper induction.
Mike_XS
PostPosted: Thu Jun 02, 2011 12:01 am Up
I didn't think they would be that cheap! I've got a friend of mine getting prices for me. But I might consider either putting uprated dampers on or coilovers.
