Online Now [145]:
Visitors: 144
Members: 1
Today: 28169
Total: 138707350
Forums › The Car › 206 Problems › Key stuck in the ignition
Junglist206
PostPosted: Thu Jun 02, 2011 1:48 am Up
Hi guys, This morning my dad went out to work got in the car put the key in the ignition. The key wouldn't turn to start it. And the key won't come out. I don't wanna pull it incase I brake it. Any ideas? Any help would be great Smile It's 1.1 L
Cheers Matt
iainlovatt
PostPosted: Thu Jun 02, 2011 1:54 am Up
have you ever got the key stuck in there before? or been awkward to put in?
(My Garage)
Junglist206
PostPosted: Thu Jun 02, 2011 2:11 am Up
No never been stuck before or awkward. I dunno why it's done it.
JE_180
PostPosted: Thu Jun 02, 2011 2:17 am Up
could try some ptfe spray or something to loosen it up?
Junglist206
PostPosted: Thu Jun 02, 2011 2:19 am Up
Tried spraying some WD40 in ignition in hopes it loosen the key but no luck Sad
JE_180
PostPosted: Thu Jun 02, 2011 2:25 am Up
tried wiggling the steering wheel side to side etc. whilst trying to move the key?
PostPosted: Thu Jun 02, 2011 2:28 am Up
+1
Junglist206
PostPosted: Thu Jun 02, 2011 2:31 am Up
I try that now cheers for the replys Smile
JE_180
PostPosted: Thu Jun 02, 2011 2:36 am Up
Cool, let us know how you get on Smile
Junglist206
PostPosted: Thu Jun 02, 2011 2:43 am Up
Still no luck Sad can't even start the car?
Junglist206
PostPosted: Thu Jun 02, 2011 3:24 am Up
Any more ideas?
iainlovatt
PostPosted: Thu Jun 02, 2011 3:41 am Up
really try turning the steering down to the right/left (doesnt matter) hard as you can then turn the key! Very Happy
(My Garage)
Junglist206
PostPosted: Thu Jun 02, 2011 3:50 am Up
I go and try that now. Cheers mate Smile
JE_180
PostPosted: Thu Jun 02, 2011 4:23 am Up
Could try giving a peugeot garage a ring see if they'd offer some 'advice'... most likely reply will be "bring it in for us to take a look at it"..
Junglist206
PostPosted: Fri Jun 03, 2011 2:07 am Up
It worked I turned the steering wheel all way to the right. Had no luck with geting the key out. Then turned it all way to the left then it just releases it to pull out.
