Latest: tbafonso
Overall: 17130
Online Now [374]:
Visitors: 373
Today: 30199
Total: 102874044
Forums › The Car › 206 Talk › Gunson Eezibleed kit
PostPosted: Sun Jun 05, 2011 8:28 am Up
I know Mr BSi knows a thing or two about these. At £16.99 it's too cheap to ignore. Question is, do they come with caps that will fit the 206 reservoir?
www.screwfix.com/p/gun...leed%20Kit
richpowell91
PostPosted: Sun Jun 05, 2011 8:55 am Up
Im also interested in buying one of these, i remember reading somewhere that if you have a halfords trade card then you can get £5 off in halfords meaning you can get it for £15. As tesco say every little helps.
If they definately fit 206's with a cap out of the box thats where i will be getting one from.
Matt
PostPosted: Sun Jun 05, 2011 8:59 am Up
Trade Rating: +32
Lee (HDi) said yea they do.
PostPosted: Sun Jun 05, 2011 9:06 am Up
The cap on my Eezibleed fits my 206 so unless they have changed the design in the last 15 years it will be fine.
Remember to drop the tyre pressure down to less then 15psi on the wheel you are using to provide the air pressure to the Eezibleed.
PostPosted: Sun Jun 05, 2011 9:30 am Up
Good stuff, I'll be ordered on then. Thanks!
PostPosted: Sun Jun 05, 2011 9:34 am Up
f*****g useless forum text talk editor Twisted Evil
spud_gti
PostPosted: Mon Jun 06, 2011 3:04 am Up
as above, really good piece of kit
2004 GTI 180 - SOLD, 2000 GTI - SOLD, 2002 SW D TURBO - CURRENT
