Latest: S2cgm
Overall: 17178
Online Now [537]:
Visitors: 537
Today: 35297
Total: 137102339
Forums › The Car › 206 Problems › front fogs help !!!
front fogs help !!!
Go to page Previous  1, 2, 3, 4
skard
PostPosted: Mon Jun 06, 2011 6:41 am Up
a pug/citroen dealer/specialist would have it and it takes minutes to do, so you'll be charged an hours labour at most.
i have the cable to do it but when i retrofitted the fogs had to pay a guy to activate them for me. maybe there's someone on the forum near you with PP2000?
yes the fuse box is easy to swap, once you've shut down the BSI and disconnected battery, it's a straight swap over.
go out and check you definitely don't have the fuse first though, it could make it a lot easier for you should it already be there.
rudymason
PostPosted: Mon Jun 06, 2011 6:55 am Up
so its the f6 fuse ill go check in a minute n let you know !! if its already there will i still need them to be activated or will it just need to be put in its correct place :S sounds to me like im talking s**te lol!!
skard
PostPosted: Mon Jun 06, 2011 7:03 am Up
if you have the fuse (or at least a slot where you can insert a fuse) then you will only have to physically plug the looms into the fog units, and still get it activated through the BSI by computer.
rudymason
PostPosted: Mon Jun 06, 2011 5:16 pm Up
awesome thanks for our help , checked today the gaps there but the ability to insert not so good !! so new fuse box and garage here i come Smile
Page 4 of 4
