Online Now [560]:
Visitors: 559
Today: 187596
Total: 146642476
Forums › The Car › 206 Talk › Dials / compatibility with other models
Forum Index › 206 Talk
devman
PostPosted: Mon Jun 06, 2011 8:30 am Up
Hi all
I've got a pre-plex 2.0 HDi, and my speedo is shot.
I know there are the 1 plug and 2 plug variants, and I know there are the low spec and high spec variants, but do they vary between engine types? I.e Would a petrol set of dials fit mine?
Cheers Smile
2000 206 2.0 HDi China Blue
1997 Jaguar XJ6 3.2 Sapphire Blue
Rob2859
PostPosted: Mon Jun 06, 2011 9:02 am Up
I do not think petrol ones fit iirc
devman
PostPosted: Mon Jun 06, 2011 9:12 am Up
Bugger.
copey
PostPosted: Mon Jun 06, 2011 9:20 am Up
also remember if petrol ones did fit, they would go right round to like 7/8k rpm, where as a diesel doesnt go that high
02 2.0 hdi d turbo
perry081064
PostPosted: Mon Jun 06, 2011 10:02 am Up
should have a part number on the back , and you will also see if they are 1 or 2 plug.
.. just pull the cowling towards you, then its one torx screw to remove.
there's also a code just under the speedo side at the front, but im not sure if this is relevent.
iirc there are 2 variants of the pre-plex type , exp important if fitting lockwood dials.
if you can take a pic ill compare with mine Wink
206 2.0 HDI
