Online Now [546]:
Visitors: 545
Today: 16256
Total: 105058590
Forums › The Car › 206 Problems › Glove-box Light
Glove-box Light
iainlovatt
PostPosted: Sat Jun 04, 2011 2:08 pm Up
Right installed the light and installed the sensor, plugged them in,
Nothing,
Had a brief look at fuses and it would seem they are all on one loom and so one fuse, this fuse is the main interior light as well as other electrics,
Any ideas people?
will uploading a pic of my fuse box help?
cheers Very Happy
(My Garage)
Nat-T
PostPosted: Sat Jun 04, 2011 2:14 pm Up
Have you tried it with the ignition on as they only work with it on?
Nat-T
Euro/Smoothed 2003 China Blue Verve
Rayvern Hydraulics
Schmidt 3-piece splits/Mercedes Wheels + custom adapters to 5x112
Lots of smoothed custom bodywork Wink
iainlovatt
PostPosted: Sat Jun 04, 2011 2:19 pm Up
Nat-T
LOL
Thanks, didnt know that!!
PROBLEM SOLVED!!
(My Garage)
Nat-T
PostPosted: Sat Jun 04, 2011 2:24 pm Up
Thats ok mate, glad I could help Smile
It would be so much better if it worked without the ignition on tho Sad
Nat-T
Rayvern Hydraulics
PostPosted: Sat Jun 04, 2011 2:25 pm Up
Rewire the ignition feed to the constant +12v feed
Nat-T
PostPosted: Sat Jun 04, 2011 2:30 pm Up
True, very true.
Think I might have a go at that at some point Wink
Nat-T
Rayvern Hydraulics
perry081064
PostPosted: Sat Jun 04, 2011 2:31 pm Up
this is why they call him " the simon cowell of electronics" Laughing
206 2.0 HDI
Rob2859
PostPosted: Sat Jun 04, 2011 6:49 pm Up
I have just bought a light and switch but the wires for them are nowhere to be found :s
PostPosted: Sat Jun 04, 2011 7:02 pm Up
Pull a line from the cigarete-lighter socket.
You will need to take-off the centre section so you can get to the wires underneath.
Disconect battery first and make a good job of it.
Rob2859
PostPosted: Sun Jun 05, 2011 5:52 am Up
ugh more effort. I was under the impression that the plugs would be there already
PostPosted: Sun Jun 05, 2011 6:43 am Up
Yep. But it's worth it.
If yours is non-multiplex you can do it so it works even with ignition off.
stevedude
PostPosted: Sun Jun 05, 2011 8:11 am Up
have a good rummage around behind the stereo area, as someone may have tied them up out of way?, im sure there is pics of the wires and plugs on here somewhere,
Happydays
PostPosted: Sun Jun 05, 2011 8:54 am Up
Not present on all models but worth a try.
iainlovatt
PostPosted: Sat Jun 11, 2011 3:02 pm Up
My model of 206 was the lowest i thought, STYLE! Mine were out of the way had a good rummage few year ago, found them, then the other day wired them in! Smile
(My Garage)
Rob2859
PostPosted: Sat Jun 11, 2011 6:30 pm Up
LX is the poverty spec. I have a fairly good spec one so thought it would have them.
