Latest: Kifi69
Overall: 17183
Online Now [507]:
Visitors: 506
Today: 116541
Total: 144576218
Forums › The Car › 206 Problems › Changing Fuel Pump, Any Tips?
sheehan879
PostPosted: Mon Jun 13, 2011 7:49 am Up
After trying everything I finally took the car to the garage, apparantly its the fuel pump. They wanted 220 to fit a new one but GSF only want 82 including VAT so I will attempt it myself.
It seems easy from the Haynes manual, just wondering if anyone had any tips that has done it before.
Many thanks,
Jase
Cheers,\r\n\r\nJase
orangeGTI
PostPosted: Mon Jun 13, 2011 7:51 am Up
1 tip i can give you is dont take it to peugeot to get it done cost us £500
For vinyl sticker please look at www.206info.co.uk/Foru...30851.html
Or PM me.
JE_180
PostPosted: Mon Jun 13, 2011 7:54 am Up
f*** me.... Peugeot seem to take the p**s alot.
orangeGTI
PostPosted: Mon Jun 13, 2011 8:01 am Up
tell me about it
Or PM me.
sheehan879
PostPosted: Mon Jun 13, 2011 8:07 am Up
I thought 220 was a bit steep, it was bad enough I paid £30 for 4 injector seals which were just O rings.
Cheers,\r\n\r\nJase
PostPosted: Mon Jun 13, 2011 8:23 am Up
Fuel pumps are a piece of cake, took me about 10 minuites to get the one out of my mates GTI, that was including taking the rivets out of the panel over it. Only thing that gives grief is the seal around it.
NICKST
PostPosted: Mon Jun 13, 2011 8:47 am Up
Tip don't smoke while doing it lol. But seriously do it your self it isn't hard.
MrrNoName
PostPosted: Mon Jun 13, 2011 11:09 am Up
agreed
PostPosted: Mon Jun 13, 2011 11:20 am Up
Have you removed the metal access panel?
sheehan879
PostPosted: Mon Jun 13, 2011 11:30 am Up
It was not there, just the plastic cover. Probably been done before.
Cheers,\r\n\r\nJase
bezford
PostPosted: Thu Apr 19, 2012 2:05 pm Up
It took a 30years+ technician using a special wide flat ended screwdriver/chisel type tool but blunt and big so not to cut into the plastic that was about 22inches long and a large powder shot hammer and his expertise and sheer determination and about 30mins non stop to remove the big black ring that is threaded on the top of a fuel tank holdin a fuel pump,so its a b***h unless u get an easy one?i cant even get the ring nut back on having replaced the o ring(which is recommended to do every time)and fit a new black threaded ring(too much damage gettin it off to go back)ive had to settle for a half crossed half a turn that seems tight enough and a very slight leak(which was my problem to begin with)but now when the car is running the fuel pump runs non stop but i cant remember if it did before?so if u can help please do?(also the new o ring and big black threaded nut are available from peugeot and i paid £3.50p for each part so seven quid-cheap enuf just a nightmare job to do).
R.HYDE
PostPosted: Thu Apr 19, 2012 2:18 pm Up
The pump runs non stop when the engine is running.
PostPosted: Sun Apr 22, 2012 11:48 pm Up
I've never seen the metal plate actually installed from the factory, so I doubt yours has been replaced before.
