Latest: tbafonso
Overall: 17130
Online Now [299]:
Visitors: 298
Today: 18312
Total: 104069032
Forums › The Car › 206 Problems › lighting problem
lighting problem
samsam
PostPosted: Tue Jun 14, 2011 4:24 pm Up
[i]hi,new to this site,but looks good,hope someone can help me,i have a 206 verve hdi,recently my sidelights have stopped working (front and back)also rear fog light constantly on,even when ignition is off.have been told it could be the ecu/relays or fuses,i just don't know where to start!
i have fitted angel eye h/lamps and all was ok for a few weeks.would these cause problems with the CAN system?
baarff!
PostPosted: Tue Jun 14, 2011 4:29 pm Up
Year of car?
Did you remove the battery when installing the lights?
Did the problem arise since you installed the lights?
ukskater01
PostPosted: Tue Jun 14, 2011 4:33 pm Up
I wouldn't of thought your angel eyes would effect your electrics, what year is your car? You may need to do a bsi reboot. Also get your battery, relays under the steering wheel and fuses checked.I'm sure someone else will be able to help you out more
Cheers
PostPosted: Tue Jun 14, 2011 5:08 pm Up
I had a similar problem a while ago which incidently also started a few weeks after i put my old angel eyes on. With mine all the lights stayed on and couldnt be turned off, turns out mine was caused by a fault with the tracking device i have on mine which was caused by changing the lights over and not disconnecting the battery. As said above though try a BSI reboot, failing that swtich the lights back over and see if its the cause of the problem...
MrrNoName
PostPosted: Wed Jun 15, 2011 1:48 am Up
unplugging the battery (correctly) should ALWAYS be step 1 Wink
PostPosted: Wed Jun 15, 2011 1:52 am Up
This man speaks the truth
samsam
PostPosted: Thu Jun 16, 2011 3:03 pm Up
thanks for the replies,year of my car is 56,will try checking relay etc at the weekend,
baarff!
samsam
PostPosted: Thu Jun 16, 2011 4:13 pm Up
how do i reboot the BSI? Can i do it myself?
baarff!
