Latest: Stu-mill
Overall: 17131
Online Now [63]:
Visitors: 62
Today: 619
Total: 104888291
Forums › The Car › 206 Talk › Identify rusty pictures
Go to page Previous  1, 2
PostPosted: Thu Jun 16, 2011 5:51 am Up
bisphenol-a wrote:
maybe i should get a car ramp like yours first. i have a really cramped up garage where i have to be careful how i swing my doors open when i get home. what would be ideal when it comes to lifting the car up to work on? stands or ramps?
Ramps are much better and safer, isn't a debate really but both have uses as you can work on the car with wheels off on ramps.
bisphenol-a
PostPosted: Thu Jun 16, 2011 5:53 am Up
thanks for the tip. i thought about it and i see myself removing the wheels and changing brakes and all that etc. i guess stands is what i need but i like the thought of ramps being safer too. Confused
PostPosted: Thu Jun 16, 2011 5:57 am Up
Ramps are easy to use but if you need access underneath with the wheels off you'll need axle stands.
PostPosted: Thu Jun 16, 2011 6:34 am Up
Just saw my reply I meant can't not can Laughing
I have both and use them 50/50. For playing with the torsion bars for example you need axle stands but for undersealing the car ramps are much easier and safer.
PostPosted: Thu Jun 16, 2011 8:35 am Up
The rear axle will fail & need replacing long before the rust has any effect on it.
Unless it really bothers you just leave it, its not doing any harm.
Page 2 of 2
