Latest: cogeim7
Overall: 17185
Online Now [767]:
Visitors: 766
Today: 152885
Total: 147268871
Forums › The Car › 206 Talk › Cruise control
Cruise control
Forum Index › 206 Talk
Go to page Previous  1, 2, 3 ... 17, 18, 19 ... 34, 35, 36  Next
wagsy206
PostPosted: Fri Mar 05, 2010 9:10 am Up
got one now too. £53 brand new from my local dealer Very Happy . ordered my pp2k stuff as well, and need to re-format my hard drive in some way that it will allow windows XP to install.
Wagsy206
old post count: 5000+
Team: Honda Accord
skard
PostPosted: Fri Mar 05, 2010 1:42 pm Up
well i found a stalk at a scrappies today from a 2003 xsara picasso. i've installed it and activated it through PP2000. I have done actuator tests so basically every time i press the button the software recognises it, so the stalk is physically in right.
problem being, CC just doesn't work. took the car out and had it in 4th and 5th gear over 40mph and it just didn't activate. it's the switch without speed restriction.
i went into all of the ECU modules to see if it needed activated elsewhere and found one setting in in the instrument panel, but when i change the presence of cruise to 'present' from 'missing' - the setting fails to save.
so, does anyone know how to fully activate CC in the ECU's?
Joe
PostPosted: Fri Mar 05, 2010 2:19 pm Up
do you have the correct brake anf clutch switches?
1.6 HDi. . . . The worst engine ever made
skard
PostPosted: Fri Mar 05, 2010 2:25 pm Up
i have the clutch switch
Lecktorious
PostPosted: Fri Mar 05, 2010 2:29 pm Up
Trade Rating: +59
I wonder if there is any order in which it needs to be done? Perhaps set to 'present' in the ECU and then activate through the BSi?
'98 Nile Blue 306 GTi 6
skard
PostPosted: Fri Mar 05, 2010 2:32 pm Up
i can't see it but i'm open to correction.
when i activate it in the BSI it doesn't let me change to anything but a type 1 cruise stalk, so it is detecting its presence.
Lecktorious
PostPosted: Fri Mar 05, 2010 2:34 pm Up
Trade Rating: +59
Strange that...wonder if its set-up differently for cars with the stalk without the speed limiter?
I've PM'd Steve_B to see if he can 'talk' us through the process.
skard
PostPosted: Fri Mar 05, 2010 2:37 pm Up
the option is along the lines of 'cruise control type 1 with/without speed restrictor' so i don't think there's much difference between them.
wagsy206
PostPosted: Fri Mar 05, 2010 4:37 pm Up
i thought it was a minimum of 50mph in 4th gear.
and the way it looked on service box and from what steve_b said it would only work with 6242z8 (stalk with limiter)
Wagsy206
Team: Honda Accord
skard
PostPosted: Fri Mar 05, 2010 4:56 pm Up
i was doing over 50mph in 4th and 5th.
i'll wait for someone else to try but i think it's looking doubtful on my car.
Lecktorious
PostPosted: Sat Mar 06, 2010 9:19 am Up
Trade Rating: +59
Well all, from what I've been told it CAN'T be done. It can be set-up in the BSi, but like skard has mentioned, when setting it to 'PRESENT' in the ECU it will not save or there is simply says 'NOT PRESENT'. Bit of a shame really as it can be activated in the BSi but that seems to be as far as you can go with it!
Jamie
PostPosted: Sat Mar 06, 2010 9:22 am Up
So that's it then is it? Sad
Was quite looking forward to having that for cruising 500 miles across Europe!
Lecktorious
PostPosted: Sat Mar 06, 2010 9:24 am Up
Trade Rating: +59
Seems to be, unless Steve_B can shed any light on it / reveal the secret!
HDiMan
PostPosted: Sat Mar 06, 2010 9:33 am Up
It can be done according to my local Pug dealer but they want £200 plus the stalk to do it!!
2005/55 Reg 2.0 HDi 3Dr Sport in Aegean blue.
16" 307 wheels refurbished
New genuine silver dials with oil temp gauge now working too!
Rear Spolier,SP lexus rear lights,SP arches,SP bonnet grille,Sp front grille.SP bumper grille.
Locking leather covered glovebox.
Clifford cat 1 alarm
Recaro seats and rear seats trimmed to match.
Headlamp wash almost done
Gti 180 rear bumper
Morette headlights
Gti 180 carbon effect trim
Alloy stubby aerial
Centre armrest
Black alloy tax disc holder
Gti 180 carbon fibre effect door mirror caps
Carbon fibre effect door card pulls
Jamie
PostPosted: Sat Mar 06, 2010 9:40 am Up
Screw that then, I'll have a look to see if it can be activated via my standalone ECU
Page 18 of 36
