Latest: cogeim7
Overall: 17185
Online Now [660]:
Visitors: 659
Today: 41893
Total: 147561697
Forums › The Car › 206 Talk › PUG 206 Immobliser Key
Forum Index › 206 Talk
Janetsman
PostPosted: Fri Jun 17, 2011 9:46 am Up
Can anyone help please. My immobiliser key as just stopped working. I have noticed that the red light no longer appears. Is this the battery inside the key and if it is will changing it upset anything.
muxloemax Turbo
-Dave-
PostPosted: Fri Jun 17, 2011 11:46 am Up
Trade Rating: +36
Battery more than likely. I don't think changing the battery messes anything up but if it does you will just need to re-sync it with the car. To do this start the engine then press & hold the unlock button for 10 seconds to resync it.
Ex 206 Owner.
-Dave-
PostPosted: Fri Jun 17, 2011 11:47 am Up
Trade Rating: +36
Also when you open it make sure you don't lose the transponder inside the key, they have been know to fall out.
Ex 206 Owner.
Janetsman
PostPosted: Fri Jun 17, 2011 2:17 pm Up
Thanks to you both for your replies I will follow what you have said.
Regards
Rod
muxloemax Turbo
-Dave-
PostPosted: Fri Jun 17, 2011 2:22 pm Up
Trade Rating: +36
We both say No problem Laughing
Ex 206 Owner.
Janetsman
PostPosted: Tue Jun 21, 2011 6:19 am Up
fitted new battery this morning but locking system does not work although
LED still flash. I have tried re sync by switching on engine and pressing the unlock button for 10 seconds but still the same.
Does this mean I have a transponder problem? if so is there anywhere or anybody who can sort it out other than the peugeot dealers.
muxloemax Turbo
PostPosted: Tue Jun 21, 2011 6:23 am Up
If you tried using the CORRECT recync proceadure you might get somewhere Wink
You have a non plexed 206.
Janetsman
PostPosted: Tue Jun 21, 2011 7:33 am Up
Do you mean the procedure for pre plexed keys thats on the forum. I have tried that but this doesnt work. Is there another procedure for non
plexed keys which i am not aware of? I have a two button key
muxloemax Turbo
PostPosted: Tue Jun 21, 2011 7:35 am Up
This?
1. Ensure all doors are unlocked using the key.
2. Press and HOLD the large plip key button while the LED flashes continuously for 20 seconds. After 20 seconds press the small deadlock button once while still holding the large button.
3. The LED will stop flashing.
4. Release the large button and the LED will light constantly.
5. Press the large button once and the LED will go out.
6. Open the door and hold the Plip key near the Ignition switch and press the large plip button once.
7. Turn the ignition ON, wait 10 seconds and then turn the ignition OFF.
8. After 5 seconds the Plip should now operate.
Janetsman
PostPosted: Tue Jun 21, 2011 7:42 am Up
Yes I have tried this about 3 times but the LED only flashes for about 10 seconds before it goes out. I have tried the rest of the reprogramming
procedure but nothing happens. Just the LED flashes but the locking system does not work.
muxloemax Turbo
PostPosted: Tue Jun 21, 2011 7:44 am Up
Has the key ever worked with it?
Janetsman
PostPosted: Tue Jun 21, 2011 7:49 am Up
Yes i have had the car for 4 years and key stopped working last week.The LED flashers still worked but the locking system didn't.
muxloemax Turbo
PostPosted: Tue Jun 21, 2011 7:54 am Up
Well if you have followed them instruction to a T, and it still won't work, then the key is probably broke
-RAJ-
PostPosted: Tue Jun 21, 2011 7:57 am Up
this happened on my dads 406, it went in for a clutch change so they had to disconnect the battery and by doing that it some how messed the central locking up, car started fine, just no locking usinf the remote fob. we tryed all the key sync things (10 secounds one and the window down one) also did BSI reboot, even got peugeot to give us the correct instructions to make sure we were doing it right. In the end took it to a car locksmith and he had to reprogrammed both keys, even he tryed the sync thing but didnt work for him either. hope this helps
ps, have you recently disconnected the battery?
Janetsman
PostPosted: Tue Jun 21, 2011 8:28 am Up
No never disconnected the battery. However there is a bloke called Lee
who is advertising his services on the Forum which includes re
programming and repairing keys so I just hope he can help.
Anyway thanks to everybody who have replied
muxloemax Turbo
