Latest: Kifi69
Overall: 17183
Online Now [399]:
Visitors: 398
Today: 60988
Total: 143609696
Forums › The Car › 206 Problems › Electrical Problem
Electrical Problem
PaddyC
PostPosted: Sat Jun 18, 2011 7:51 am Up
I installed my stereo (not the standard one that came with the car) that I had bought for my old 306 into the 206 and everything works fine. Only now that if the stereo is off, the car switches off as normal when the key is turned to the off position and removed from the ignition barrel.
If the stereo is on, however, the car won't switch off, even if the key is put in the off position and then removed from the ignition barrel completely. Shocked
That ain't right, so what could have caused this? It wasn't doing this until I installed the stereo, so faulty wiring somewhere? It seemed fine when I switched it over, everything plugged in as before and there didn't appear to be any problems. Anyone shed some light on this?
Peugeot 206 1.4HDI Style
PostPosted: Sat Jun 18, 2011 7:53 am Up
Have you connected the car ISO plugs straight in to the back of this new radio OR is there some kind of harness the ISO are now connected to?
PaddyC
PostPosted: Sat Jun 18, 2011 8:01 am Up
The black and white plastic clips are plugged into a seperate cable that came with the stereo and then this plugs into the back of the stereo.
Norvvv
PostPosted: Sat Jun 18, 2011 8:03 am Up
Move the fuse from b to a? I think it's something like 21.
2001 1.4lx
PrePlexed 5 door.
PaddyC
PostPosted: Sat Jun 18, 2011 8:58 am Up
Move what fuse? Could you explain what exactly you mean?
PostPosted: Sat Jun 18, 2011 9:13 am Up
Cant do that on a multiplexed 206 Wink
Swop the red & yellow wires round on the back of the stereo.
PaddyC
PostPosted: Sat Jun 18, 2011 9:36 am Up
I had to do this orignally to get the stereo to work on the 306. Do I now have to reverse this so it will work on the 206?
PostPosted: Sat Jun 18, 2011 10:54 am Up
Yes, give it a try Wink
PaddyC
PostPosted: Sat Jun 18, 2011 11:18 am Up
OK, re-wired everything according to the manual and the guide on the top of the stereo. Turns out several wires were in the wrong place. I can blame my t**t of an ex-brother in law for wiring it up originally! Laughing
All working perfectly now. Car has also been given a good cleaning inside and out so went for a little spin around town with the music on. Ahhh, it's great when everything works as it should! Very Happy
I love my new 206! Very Happy
Thanks to all for your help! Cool
