Latest: lio94
Overall: 17181
Online Now [247]:
Visitors: 247
Today: 56287
Total: 141495278
Forums › The Car › 206 Talk › Cant go lower?
Cant go lower?
PostPosted: Sat Jun 18, 2011 1:28 pm Up
Right peoples,
I have a big problem, the rear needs to drop more but the arm will be resting on the chassis stopping it
Is there a way round this?
Plus i will be removing the helper springs and winding her down fully, i already have the smallest possible tyres. The coilovers are racelands, is there a other coilovers that can go lower or will i need shorter springs?
Adam Smile
PostPosted: Sat Jun 18, 2011 1:32 pm Up
front: yes, you will need shorter spring and make sure get the harder spring too.
rear: i don't know.
Abzynthe
PostPosted: Sat Jun 18, 2011 2:19 pm Up
East Area Rep - Abzynthe
Just take the suspension off altogether Razz
arronmee1990
PostPosted: Sat Jun 18, 2011 2:30 pm Up
Don't know about the rear but on the front you could raise the top mount higher to go even lower (if that makes sense)
My Project Thread
EdCherry
PostPosted: Sat Jun 18, 2011 2:37 pm Up
You can modify the mounts on most pugs to change the ride height. Specially on the olders ones, requires a fair bit of fabrication and often some welding on the car but it does the job.
Of course the arms wont move lower if they are already on the bumpstops and you dont remove them and work the chassis rail.
-Dave-
PostPosted: Sat Jun 18, 2011 2:38 pm Up
Trade Rating: +36
Airbag's FTW
Ex 206 Owner.
PostPosted: Sat Jun 18, 2011 2:41 pm Up
Ive removed the bump stops.....
So yes it will be on the chassis rail, but i dont quite get what you mean by 'you dont remove them'?
EdCherry
PostPosted: Sat Jun 18, 2011 2:42 pm Up
For example if the car was already on the bumpstops, and you modified the mounts to go lower, the car would not go lower cause it still has to sit on those bumpstops. Same if you've moved them and your sitting on the chassis rails. Get the welder out.
PostPosted: Sat Jun 18, 2011 2:44 pm Up
I removed them to go lower Laughing
So basically the chassis needs to be altered slightly, or could if the arm tubing (where they sit on the axle?) be extended/spaced to give that clearence?
arronmee1990
PostPosted: Sat Jun 18, 2011 3:17 pm Up
How come you need to go lower than flush with chassis rail on the back anyway?
Surely the sill will be on the floor?
My Project Thread
PostPosted: Sat Jun 18, 2011 3:47 pm Up
His aim will be about 10mm clearance. Wink
PostPosted: Sun Jun 19, 2011 1:41 am Up
All sounds very dangerous being so low that bumpstops have to be removed.
PostPosted: Sun Jun 19, 2011 2:10 am Up
I agree!
im all for lowering your car but not when its going to make it unsafe to drive it!!!
nakednakeddave
PostPosted: Sun Jun 19, 2011 2:30 am Up
wont necesarily make it unsafe.... just not very comfortable to drive and all your suspension bushes with seperate n die alot faster haha
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
PostPosted: Sun Jun 19, 2011 2:35 am Up
If it's bumpy it means is has no suspension. That is what keeps the tyres on the road.
