Latest: tebas93089
Overall: 17179
Online Now [70]:
Visitors: 68
Bots: 2
Today: 2019
Total: 138104110
Forums › The Car › 206 Problems › Alarm Prob - help needed
Go to page Previous  1, 2
cookiemonster
PostPosted: Sun Dec 12, 2010 12:45 pm Up
MrBSI wrote:
You tried spraying the bonnet sensor with some WD40?
Its the small black switch attached to the catch.
Check it also hasnt fallen off Laughing
just got home its dark now will take a look tomorrow - cheers Very Happy
Used to be in WRX
cookiemonster
PostPosted: Tue Dec 14, 2010 5:56 pm Up
i cant see a small black switch on catch to be honest Embarassed
Used to be in WRX
skard
PostPosted: Tue Dec 14, 2010 6:18 pm Up
best pic i found in a quick search...
the top part is the plunger switched previously referred to.
when the bonnet latches shut it should push down on this.
thus, if it has fallen off or doesn't fully engage it won't activate the alarm.
wpday07
PostPosted: Tue Jun 21, 2011 3:18 pm Up
Hi, Did you fix the problem? I also have an alarm that wont function,
the Boot/Bonnet sensors are situated in the correct place
the wiring seems to be ok to the Textron control box (Pillars are connected)
Ive tried arming it with the windows down and running my hand across the sensors, nothing happens, not even the lights flash..
the only weird thing is when i lock and unlock the car i get a strange noise as if someone *excuse this* farted.
How can i get the blinkin thing to work...
anyones help much appreciated.
W.DAY
PostPosted: Tue Jun 21, 2011 3:26 pm Up
Lock the car with the fob, then manually unlock it with the key
wpday07
PostPosted: Tue Jun 21, 2011 3:57 pm Up
hi, cheers for the quick reply, tried that, no luck :/ it just unlocks normally
W.DAY
PostPosted: Tue Jun 21, 2011 3:59 pm Up
Your alarm isn't even activating then. Possibly a problem with the control unit
wpday07
PostPosted: Tue Jun 21, 2011 4:04 pm Up
ive taken the thing out, disconnected it, reconnected it, still nothing, the fuse is ok also, yeah you could be right, thank you.
now where to buy one.. haha
W.DAY
PostPosted: Wed Jun 22, 2011 3:51 am Up
Your alarm is trying to tell you one of the doors / boot / bonnet isnt shut correctly & that means the system wont arm.
wpday07
PostPosted: Wed Jun 22, 2011 4:10 am Up
so the sensors are broken?
W.DAY
PostPosted: Wed Jun 22, 2011 4:12 am Up
Your alarm is trying to tell you one of the doors / boot / bonnet isnt shut correctly.
You need to check which sensor is stopping the alarm system arming.
wpday07
PostPosted: Thu Jun 23, 2011 7:21 am Up
thank you
W.DAY
Ash
PostPosted: Thu Jun 23, 2011 9:00 am Up
Lee wrote:
Are all the doors actually locking when you lock the car?
I've got a dicky drivers lock which doesn't always lock and that causes my alarm to not activate.
Now I know which door to try. Thanks Lee Wink Laughing
wpday07
PostPosted: Fri Jun 24, 2011 6:25 am Up
it seems that all of the sensors are ok, its a 2003 model so it shows up if the door is open etc. It must be the control box.. :/
W.DAY
PostPosted: Fri Jun 24, 2011 7:59 am Up
Needs scanning with Peugeot Planet.
Page 2 of 2
