Online Now [159]:
Visitors: 158
Today: 14595
Total: 138805089
Forums › The Car › 206 Problems › GTI 180 not so horny....
L5_UKS
PostPosted: Thu Jun 23, 2011 12:57 pm Up
Went to use my horn today only to find out it doesn't work Sad any ideas what it could be?
Luke.
MrZiggerz
PostPosted: Thu Jun 23, 2011 12:59 pm Up
Just not horny enough.
stevedude
PostPosted: Thu Jun 23, 2011 1:00 pm Up
a broken horn lol
blown fuse
loose wire
Happydays
Callum206
PostPosted: Thu Jun 23, 2011 1:09 pm Up
No horn ?
L5_UKS
PostPosted: Thu Jun 23, 2011 1:14 pm Up
stevedude wrote:
a broken horn lol
blown fuse
loose wire
Whats the fuse number for the horn? i didnt get a manual with my car so cant check the manual Sad is it the fuse box in the car or the one under the bonnet?
Luke.
L5_UKS
PostPosted: Thu Jun 23, 2011 1:15 pm Up
Callum206 wrote:
No horn ?
Where abouts is the horn located?
|SGP|
PostPosted: Thu Jun 23, 2011 1:16 pm Up
pop some viagra in the tank when you next fill it up Laughing
View my car
meady
PostPosted: Thu Jun 23, 2011 1:22 pm Up
Trade Rating: +45
As you look at the car it is on the front left behind the bumper. You can see it through the grille
TEAM - I HATE FACEBOOK Smile
L5_UKS
PostPosted: Thu Jun 23, 2011 1:48 pm Up
UPDATE: just been out to my car to check the fuse, took the fuse out it wasn't blown so put it back in, checked the horn again and it worked then it stopped working and now all i can hear is a clicking noise from the fuse box under the bonnet when i press the horn.
-Dave-
PostPosted: Thu Jun 23, 2011 2:10 pm Up
Trade Rating: +36
Try a different fuse just to be sure. My stereo stopped working once checked the fuse it looked fine but when I swapped next day it worked fine.
Ex 206 Owner.
L5_UKS
PostPosted: Thu Jun 23, 2011 2:14 pm Up
Tried that aswell swapped it with two fuses that was the same one (15a) but used for different things with no luck, it just clicks in the fuse box Sad
PostPosted: Thu Jun 23, 2011 2:20 pm Up
Wires will have corroded and snapped on the connector. Very common
PostPosted: Thu Jun 23, 2011 2:21 pm Up
One of the connectors on one of the horns is probably corroded.
L5_UKS
PostPosted: Thu Jun 23, 2011 2:22 pm Up
How do i go about replacing the corroded wires?
DREWDEN
PostPosted: Thu Jun 23, 2011 3:10 pm Up
I had the same problem 2 months a go, after investigation found one of the wires broken near the horn
went to scrappers thinking the horn was faulty wasted £6
206 2ltr Hdi glx 53 plate
