Latest: tebas93089
Overall: 17179
Online Now [110]:
Visitors: 110
Today: 53425
Total: 138471817
Forums › The Car › 206 Talk › Peugeot 206 BSI units
Janetsman
PostPosted: Thu Jun 23, 2011 5:36 am Up
Can anybody tell me if these BSI units are interchangeable for instance
if bought second hand. I know they have to be re programmed but
do i have to get the precise Siemens part no that is on the unit. any help
would be appreciated
muxloemax Turbo
PostPosted: Thu Jun 23, 2011 9:46 am Up
You CANNOT reprogram a 2nd hand BSI unit.
Go buy a NEW one from your Peugeot main dealer.
OR
Get your old one tested / repaired by BBA
www.bba-reman.com/uk/index.aspx
Rob2859
PostPosted: Thu Jun 23, 2011 10:05 am Up
Why can the old one be reprogrammed but a second hand one can not? Are they not physical identical?
Abzynthe
PostPosted: Thu Jun 23, 2011 10:08 am Up
East Area Rep - Abzynthe
Something to do with a security code in the ECU for the BSI to communicate with. It cant be changed, and the ECU and BSI have to have the same code.
I think...
PostPosted: Thu Jun 23, 2011 10:10 am Up
You cant reprogram the old one either.
The only things you can do is:
Update the software version
Reconfigure the BSI setup
Recode keys
The VIN number & mileage are extremly difficult to alter / tamper with.
A brand spanking new BSI from Peugeot is cheap enough anyway.
Rob2859
PostPosted: Thu Jun 23, 2011 10:15 am Up
I see. I didn't realise a BSI can only be programmed once. I hope I don't end up going down this road anyway. Will have to see what the auto electrician says.
I take it the OP's is bust?
PostPosted: Thu Jun 23, 2011 11:19 am Up
Mileage is easy enough to change, if you have a programmer
You can virginise a BSI, but its just too expensive because you need to change some of the eeproms and then recode it all, its cheaper to buy a new one and recode it.
If you get a second hand BSI, and remove the coding for the immo it will work.
Janetsman
PostPosted: Thu Jun 23, 2011 3:58 pm Up
Thanks for your replies just one question puzzles me. There must be over a hundred second hand units on EBay for sale. Why would anybody buy these units if they cannot be recoded. I checked with BBA this morning and they can rebuild faulty units and give a 2 year warranty for approx £100 but I didnt ask them
how quick they could do it.
muxloemax Turbo
PostPosted: Thu Jun 23, 2011 4:18 pm Up
Why are you buying a new BSI?
They work with the corresponding ECU and transponder, or if you remove the IMMO
Janetsman
PostPosted: Fri Jun 24, 2011 12:25 am Up
thanks for your message so whats the best option to replace with a used
ECU, BSI Unit and transponder or to simplify whats the best cost effective
way to get my locking system working again
muxloemax Turbo
PostPosted: Fri Jun 24, 2011 3:45 am Up
Getting it looked at by someone that knows what there doing for a start.
Just throwing parts at it in the hope of fixing it shouts " I aint got a clue what im doing " Wink
Rob2859
PostPosted: Fri Jun 24, 2011 4:40 am Up
It could easily be a broken wire or bust relay. My battery spazzed out my electrics and bust my electric windows, I need to get my car running right first but the BSI is not the first place I will be looking as it is the most expensive.
Ali_H
PostPosted: Fri Jun 24, 2011 4:41 am Up
Isn't this a bit like using a sledgehammer to crack a nut?
kurtis wrote:
Janetsman
PostPosted: Fri Jun 24, 2011 5:47 am Up
Yes I agree very sensible advice I am going to get a diagnostics check this afternoon I will let you know the outcome thanks
again for your interest
muxloemax Turbo
Janetsman
PostPosted: Fri Jun 24, 2011 11:41 am Up
My car was checked this afternoon BSI unit is OK the drivers door activator is faulty so got there in the end
muxloemax Turbo
