Latest: Kifi69
Overall: 17183
Online Now [497]:
Visitors: 496
Today: 105818
Total: 144123656
Forums › The Car › 206 Problems › 180 radius arms
180 radius arms
chantilbury
PostPosted: Thu Jun 23, 2011 1:57 pm Up
Im new to this but i have a question about the rear arms that go from the centre rear of car to each hub,how much are they to replace and are they a straightforward replacement,I.E:-im no mechanic but have a basic knowledge of suspension function??any info will help..cheers .. Confused Confused
why does theft not apply to politicians!
PostPosted: Thu Jun 23, 2011 1:59 pm Up
i think is about GBP400-600 parts only (each side)
Lecktorious
PostPosted: Thu Jun 23, 2011 2:09 pm Up
Trade Rating: +59
It's the lateral arms the blokes asking about, not the trailing arms Wink
'98 Nile Blue 306 GTi 6
PostPosted: Thu Jun 23, 2011 2:19 pm Up
Peugeot charge 2 hours labour
They are £76.76 each, part numbers 5150 91 and 9150 92
|SGP|
PostPosted: Thu Jun 23, 2011 3:01 pm Up
Can you get bushes for these? I'm pretty sure mine are worn and causing a clanking noise at the rear.
I'd have thought it'd be cheaper than spending £150 on the actual arms?
and to be clear, these are the arms going from the centre to the wheel you can see very clearly under the car from the rear?
View my car
PostPosted: Thu Jun 23, 2011 3:05 pm Up
Nah just a washer and nut and bolt by the looks of it on the diagram
|SGP|
PostPosted: Thu Jun 23, 2011 3:13 pm Up
yeah on the diagram, (if we're looking at the same thing) where 74 and 75 thread together, there's a bush there; on mine it's worn away.
I suppose it only comes with the arm? the robbing b******s!
View my car
PostPosted: Thu Jun 23, 2011 3:21 pm Up
Integrated part
chantilbury
PostPosted: Thu Jun 23, 2011 11:10 pm Up
thanks for the replys peeps,done a bit research and peugeot only sell the arms as a unit and dont sell the bushes seperate!! £75 each!! a mate of mine ive found out used to work at a peugeot dealer so hopefully i can get them a trifle cheaper...thanks again..
chantilbury
PostPosted: Fri Jun 24, 2011 8:26 am Up
further to my earlier enquiry about the radius arms,looking under the vehicle there seems to be easy access to release the bolts holding them?is there a technique to replacing them/special tools required?i cant understand why thieving peugeot main dealers charge 2 hours labour and id like to do them myself???? Cool
PostPosted: Fri Jun 24, 2011 8:32 am Up
They have to charge what Peugeot head office tell them to, the dealer is just going by the book.
chantilbury
PostPosted: Fri Jun 24, 2011 8:47 am Up
Yeah i understand that,all im wondering is why two hours??4 bolts two arms? as i said is the job difficult?? there must be some difficulty for 2 hours labour?i was only charged 103 quid for them to replace a gearbox oil seal that i knackered when i changed the lower arms???
PostPosted: Fri Jun 24, 2011 9:06 am Up
I've emailed you a guide on how to replace them, and its not two hours is 1.9 hours to be precise.
chantilbury
PostPosted: Fri Jun 24, 2011 12:17 pm Up
thanks so much for that lee..bob.. Smile
|SGP|
PostPosted: Fri Jun 24, 2011 1:13 pm Up
Could I have a copy to see what's involved? Smile
View my car
