Latest: Puggingalong
Overall: 17129
Online Now [186]:
Visitors: 185
Today: 27985
Total: 100881680
Forums › The Car › 206 Problems › Squeeky Boot - 180
Squeeky Boot - 180
keeno
PostPosted: Sun Jun 26, 2011 9:23 am Up
The boot is starting to squeek all the time now, there is nothing loose, i have WD40ed the hinges ect when im driving around.
When the boot is closed and you push it slightly it squeeks also.
I have even taken the panel off the boot to see if its anything in there, but evrything is solid.
Sad
206 Gti 180
PostPosted: Sun Jun 26, 2011 9:27 am Up
Is it actually the hinges that are squeaking?
Use grease/oil rather than WD40
keeno
PostPosted: Sun Jun 26, 2011 9:31 am Up
i dont think it is, it seems to be coming from just below the numberplate.
206 Gti 180
dopey
probably the spare wheel, mine is a b***h for it, or it could be the boot latch sometime they do it!
keeno
PostPosted: Sun Jun 26, 2011 9:36 am Up
it hasnt got a spare wheel!
206 Gti 180
PostPosted: Sun Jun 26, 2011 9:37 am Up
It will be the boot catch then
keeno
PostPosted: Sun Jun 26, 2011 9:42 am Up
any ideas how to stop it?
206 Gti 180
dopey
PostPosted: Sun Jun 26, 2011 9:44 am Up
Get a new boot catch.
PostPosted: Sun Jun 26, 2011 9:45 am Up
Try lubricating / adjusting the catch.
xspongerx
Mine started squeaking, I took the boot catch off, degreased it all, greased it all back up then fitted it again...
try that Smile
keeno
PostPosted: Sun Jun 26, 2011 9:49 am Up
sweet, ill do that tomoz Smile
206 Gti 180
PostPosted: Sun Jun 26, 2011 9:52 am Up
White lithium grease is good
BailedC30
PostPosted: Sun Jun 26, 2011 10:03 am Up
look at the piece of plastic that your boot actually latches onto. you can spin the piece of plastic and you will more than likely find a groove worn out of it. i just wrapped some electrical tape around it and it never did it again. lol
keeno
PostPosted: Sun Jun 26, 2011 10:06 am Up
cheers matey
206 Gti 180
MrrNoName
PostPosted: Sun Jun 26, 2011 10:41 am Up
wrap some electrical tape around the boot catch bar, as said above, it works virtually every time, its a common problem with all cars where the boot is frequently used Smile
