Posted: Sun Jun 26, 2011 9:23 am |
The boot is starting to squeek all the time now, there is nothing loose, i have WD40ed the hinges ect when im driving around.
When the boot is closed and you push it slightly it squeeks also.
I have even taken the panel off the boot to see if its anything in there, but evrything is solid.
Posted: Sun Jun 26, 2011 9:27 am |
Is it actually the hinges that are squeaking?
Use grease/oil rather than WD40
Posted: Sun Jun 26, 2011 9:31 am |
i dont think it is, it seems to be coming from just below the numberplate.
probably the spare wheel, mine is a b***h for it, or it could be the boot latch sometime they do it!
Posted: Sun Jun 26, 2011 9:36 am |
it hasnt got a spare wheel!
Posted: Sun Jun 26, 2011 9:37 am |
| keeno wrote: |
| i dont think it is, it seems to be coming from just below the numberplate. |
It will be the boot catch then
Posted: Sun Jun 26, 2011 9:42 am |
any ideas how to stop it?
Posted: Sun Jun 26, 2011 9:44 am |
Get a new boot catch.
Posted: Sun Jun 26, 2011 9:45 am |
| keeno wrote: |
| any ideas how to stop it? |
Try lubricating / adjusting the catch.
Mine started squeaking, I took the boot catch off, degreased it all, greased it all back up then fitted it again...
try that
Posted: Sun Jun 26, 2011 9:49 am |
sweet, ill do that tomoz
Posted: Sun Jun 26, 2011 9:52 am |
White lithium grease is good
Posted: Sun Jun 26, 2011 10:03 am |
look at the piece of plastic that your boot actually latches onto. you can spin the piece of plastic and you will more than likely find a groove worn out of it. i just wrapped some electrical tape around it and it never did it again. lol
Posted: Sun Jun 26, 2011 10:06 am |
cheers matey
Posted: Sun Jun 26, 2011 10:41 am |
wrap some electrical tape around the boot catch bar, as said above, it works virtually every time, its a common problem with all cars where the boot is frequently used
Any work you undertake as a result of my posts is done so at your own risk  | |
