Online Now [646]:
Visitors: 645
Today: 40988
Total: 146939532
Forums › The Car › 206 Problems › Odd misfire :-/
Odd misfire :-/
Go to page Previous  1, 2
PostPosted: Sat Jun 25, 2011 4:53 am Up
jaybooooi wrote:
MrBSI wrote:
Might be worth checking / replacing the spark plugs first.
Nice set of Bosch super plus plugs are cheap enough.
Hope it aint running NGK's Wink Laughing
Can I ask what is wrong with running ngk spark plugs?
www.206info.co.uk/Forums/search/
Its been covered many times before.
Rob2859
PostPosted: Sat Jun 25, 2011 5:17 pm Up
whether the light is on or not. Get it diagnosed. It should be of of the first things to do in any situation.
sicskate
PostPosted: Sun Jun 26, 2011 10:26 am Up
Trade Rating: +13
Car won't even start now... Turns over nicely.
I'm guessing the coilpack is brown bread?
307 1.4hdi Smile
PostPosted: Sun Jun 26, 2011 10:27 am Up
sure its not the immo now?
get it scanned, instead of throwing parts at it
sicskate
PostPosted: Sun Jun 26, 2011 10:32 am Up
Trade Rating: +13
I can't get it tested unless I get it transported to a garage as its stuck at the back of my drive.
Is there anyway around an immobiliser issue?
307 1.4hdi Smile
PostPosted: Sun Jun 26, 2011 10:34 am Up
Try the spare key
sicskate
PostPosted: Sun Jun 26, 2011 10:37 am Up
Trade Rating: +13
Lost it a few weeks back when moving house Sad
307 1.4hdi Smile
sicskate
PostPosted: Sun Jun 26, 2011 1:25 pm Up
Trade Rating: +13
No fuel getting to the rail.
So guessing you are correct.
Are there any other ways around this, or will I have to order a new key and post it to you ect?
307 1.4hdi Smile
PostPosted: Sun Jun 26, 2011 1:39 pm Up
You've not hit the fuel cut off switch have you? Big red/black button behind the battery
sicskate
PostPosted: Sun Jun 26, 2011 1:53 pm Up
Trade Rating: +13
Nope, not that I know of.
It was running last night, didn't touch it untill this morning.
307 1.4hdi Smile
PostPosted: Mon Jun 27, 2011 7:58 am Up
Ignition OFF but key in barrel, open drivers door & listen.
If you can hear a beep then the immobiliser should be working correctly.
Doubly relay is also favourite on this non plexed 206's, think it lives under the engine ecu.
Crank sensor is also a likely failure as well.
sicskate
PostPosted: Mon Jun 27, 2011 12:22 pm Up
Trade Rating: +13
Ok... I Turned it over this evening and no fire.
Left the key in the car, tried again 10 mins later and it's alive!
But now the rad temp guage is being gay.
It's flipping round 3 times on start up, reading abit high and the fan is on even when I can grab the rad pipes and touch the head with my hand.
Possible thermostat or rad temp sensor??
307 1.4hdi Smile
Page 2 of 2
