Online Now [304]:
Visitors: 303
Today: 14761
Total: 142283277
Forums › The Car › 206 Problems › drop links
drop links
gaznandrea
PostPosted: Mon Jun 27, 2011 1:15 pm Up
i need two replace mine are they easy to do as it failed mot cheers gaz
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
PostPosted: Mon Jun 27, 2011 1:17 pm Up
easy only if you can unbolt the old one, or you will have to grind it off.
unbolt the old one and put the new one on.
meady
PostPosted: Mon Jun 27, 2011 1:20 pm Up
Trade Rating: +45
Its literally juat two bolts on each side mate. If they get stuck then you will have to cut thm off as said but thts easy enough
TEAM - I HATE FACEBOOK Smile
Rob2859
PostPosted: Mon Jun 27, 2011 1:22 pm Up
I had to grind mine off. I shaved my brake pipe though couldn't have been any closer Very Happy
PostPosted: Mon Jun 27, 2011 1:28 pm Up
if you dont have a grinder handy clamp some mole grips onto the rubber side then undo the nut Wink
some have also have slots on the back too to put a spanner on too , Wink
Rob2859
PostPosted: Mon Jun 27, 2011 1:35 pm Up
I had a torx figment in mine but i just rounded the bits off. I also put some big grips on as tight as i possibly could and it was not enough.
gazza82
PostPosted: Mon Jun 27, 2011 2:09 pm Up
Soak the nuts for a couple of days with penetrating oil first (NOT WD40 ... something like PlusGas!)
PostPosted: Mon Jun 27, 2011 2:10 pm Up
Just cut them off, cheap enough to replace with new.
PostPosted: Mon Jun 27, 2011 2:20 pm Up
Grinding them is the easier way if they have been fitted longer than a year max. Just be careful if you do and make sure you tie the abs cables well away if you have them.
doughboy5
PostPosted: Mon Jun 27, 2011 4:09 pm Up
i cut mine off easy as aything either that or use a small torx key. just be carefull of the brake lines i grazed mine too. lol
206 GTi
Rob2859
PostPosted: Mon Jun 27, 2011 4:20 pm Up
brake cleaner is very good for sized bolts.
