Posted: Mon Jun 27, 2011 2:54 pm |
Hi Folks
Diagnostics test picked up a sensor fault on accelerator pedal, been told you have to replace the whole pedal to solve the problem is this true.?
Having no problems at all with accelaration and power.
What should i do. any suggestions welcome.
| 206 2ltr Hdi glx 53 plate | |
Posted: Mon Jun 27, 2011 2:56 pm |
You sure its the accelerator pedal? as they rarely fail. Its normally the throttle position sensor
Posted: Mon Jun 27, 2011 3:12 pm |
Very nicely said LEE. It is the throttle position sensor. where's it located, my friend who did the diagnostics said it was in the pedal.
Posted: Mon Jun 27, 2011 3:15 pm |
open the bonnet, look near the airbox its there. If you get someone to rev the car you can see it move.
Posted: Mon Jun 27, 2011 3:19 pm |
There-ish
Posted: Mon Jun 27, 2011 3:44 pm |
Fantastic. much appreciated
Just wandering? does the sensor affect the MPG you do as I've noticed a drop recently.
Posted: Mon Jun 27, 2011 3:48 pm |
Probably will do as the throttle and revs are all over the place.
Was ridiculous when mine was faulty, could never hold a constant speed.
Posted: Mon Jun 27, 2011 4:06 pm |
Looks like i've been lucky, not got to your stage
better get it fixed when i take it for MOT tomorrow
How much does the sensor cost.
Posted: Mon Jun 27, 2011 4:12 pm |
Part Number 1920 AK @ £77.53
Posted: Mon Jun 27, 2011 5:34 pm |
OUCH wasn't expecting that, what about scrappers would it surfice or would there be problems.
Posted: Tue Jun 28, 2011 4:09 am |
Buy a new one. As the used one might be as knackered as yours
