Latest: Puggingalong
Overall: 17129
Online Now [225]:
Visitors: 224
Today: 33829
Total: 101073671
Forums › The Car › 206 Problems › radio help needed!
radio help needed!
Danw_VVT
PostPosted: Tue Jun 28, 2011 1:43 am Up
hey guys, my radio doesnt work....well it does but doesnt
i turn on ignition and display is blank radio doesnt come on and none of the buttons work on radio or steering control stalk ( radio one )
however if i put a cd in it plays still nothing on display and i can control the track and volume but still cant switch to radio or have anything on the display. but then when i got to turn the car off it still plays the cd and i cant turn it off only way is taking the CD out and then it stops?!
any suggestions? would a BSI reset do the trick?
cheers
dan
Danw_VVT
PostPosted: Tue Jun 28, 2011 2:10 am Up
PLEASE SOMEONE Sad
Big_Rich180
PostPosted: Tue Jun 28, 2011 2:49 am Up
Are all the cables in correctly at the back??
Maybe time for a new head unit, but I know jack about audio so its just a long shot.
PostPosted: Tue Jun 28, 2011 2:53 am Up
I doubt a BSI reset will do anything, sounds like the head units died to me.
Danw_VVT
PostPosted: Tue Jun 28, 2011 2:56 am Up
:'( Yeah cables are all in place. grr thats gonna be a stealership thing isnt it? they are coded to each vehicle arent they?
PostPosted: Tue Jun 28, 2011 3:03 am Up
I'd have thought any 206 headunit would work in your car as long as you had the code.
Abzynthe
PostPosted: Tue Jun 28, 2011 3:08 am Up
East Area Rep - Abzynthe
Plexed ones dont have codes, they are linked to your vin or something like that.
Pre plexed do have codes and are interchangable though Smile
Danw_VVT
PostPosted: Tue Jun 28, 2011 3:33 am Up
yeah mines multi Sad
PostPosted: Tue Jun 28, 2011 4:03 am Up
If its not the original Peugeot radio that was fitted as standard, it needs VIN coding.
Or is it aftermarket?
Danw_VVT
PostPosted: Tue Jun 28, 2011 4:12 am Up
its the OEM one that came from factory.
PostPosted: Tue Jun 28, 2011 4:14 am Up
If everything is plugged back in, all the fuses are ok and it still won't boot up after you've had the battery off and on, then its should shafted
Danw_VVT
PostPosted: Tue Jun 28, 2011 4:22 am Up
ok ill try disconnecting that battery at lunch n reconnecting it properly of course lol
